ls/vtec
Old Nov 19, 2006 | 10:06 PM
93turbotegSAV's Avatar
Default ls/vtec
i have a 1993 turbo ls i want to do ls vtec is anybody selling an ls vtec setup?
Old Nov 20, 2006 | 02:03 AM
b18sihatch's Avatar
Default Re: ls/vtec (93turbotegSAV)
ls motors are better to turbo than lsvtec, lsvtec high compression will harm your max horsepower output
Old Nov 20, 2006 | 02:05 AM
blackeg's Avatar
Default Re: ls/vtec (b18sihatch)
stock b16 head ls block lsvtec is i think right around 9.6-9.8:1 compression, still fine for boost if you have a good tune
Old Nov 20, 2006 | 02:11 AM
b18sihatch's Avatar
Default Re: ls/vtec (blackeg)
i was refrencing to if he might have swapped out the OEM b18 pistons to gsr or itr pistons, compression would be alot higher, or if he swapped them out for PR3
Old Nov 20, 2006 | 11:58 AM
blackeg's Avatar
ohh ok. if you swapped pistons then you should at least run a thicker headgasket, but sometimes they can be not as reliable bla bla bla.... just might be best to get a different block or low comp pistons. im sure you can find a set of srp's for less than 400
hondarny08
Mar 24, 2007 10:25 AM
Damills
Jan 28, 2007 05:37 PM
wernhersey
Jul 9, 2006 08:43 PM
chuckd05
Mar 26, 2003 08:15 AM
torr
Feb 3, 2003 04:22 AM
