Did I blow my motor?
Old Nov 20, 2006 | 08:16 PM
Jerm982's Avatar
Default Did I blow my motor?
Today I was driving pretty hard, then smoke started entering the cabin and the car started running pretty rough from idle to 4000rpm after that it smooths out more. I pooped the hood oil was all over near the battery area/intake manifold area. Other than running rough, alot of air/smoke is coming out of the top of the valve cover (where oil is added). It's pulsing out like exhaust almost, if the motor is revved the pulses are consistant with rpm. If the oil cover is on, I get the same effect from the block breather... Please help!!!
99 Stock B16a
Greddy Kit
8psi
Old Nov 20, 2006 | 08:27 PM
btech's Avatar
Default Re: Did I blow my motor? (Jerm982)
blow ringlands, rings... 1st sign of smoke coming out of valvecover.... sucks.
Old Nov 20, 2006 | 08:53 PM
OBRJosh's Avatar
Default Re: Did I blow my motor? (btech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by btech &raquo;</TD></TR><TR><TD CLASS="quote">blow ringlands, rings... 1st sign of smoke coming out of valvecover.... sucks.</TD></TR></TABLE> X2
Old Nov 20, 2006 | 08:54 PM
dunkd's Avatar
werd... do a compression test before you take it apart to see how bad you smoked it.
Old Nov 20, 2006 | 09:41 PM
turbod da's Avatar
Default Re: (dunkd)
i had same thing on my trbd b16... i ended up with broken ringlands also but do a compression test before tearing into it..
Old Nov 21, 2006 | 05:01 PM
vahonda97's Avatar
i just finished my 1.5 i had in my 97 civic off .. messed my rings up , blew the water pump, and head gasket, and took a chunk out the timing belt pully.. i was getting on it .. bc i got a 98 civic ex tranny in there so my gears are really long. but i gotta new motor in it now .. d16y8 and i am bout to supercharge it.. bam...
snaileg's Avatar
damn sorry to hear your loss =\
Old Nov 21, 2006 | 05:12 PM
N20civicB18's Avatar
Default Re: (snaileg)
you either broke a ring land or melted a piston
Old Nov 21, 2006 | 05:45 PM
OBRJosh's Avatar
Default Re: (N20civicB18)
This was what happended after a pull on the highway on My stock b16, it started smoking out of the Valve Cover after i let off teh Gas [IMG][/IMG]
Old Nov 21, 2006 | 06:01 PM
Mr HYDE's Avatar
Default Re: (OBRJosh)
def blown ring langs, thats what happened when i missed shifted with my turbod stock gsr
Old Nov 21, 2006 | 08:03 PM
MidShipCivic's Avatar
My friends ''draged'' a pos 2g eclipse (420a domestic engine) to my house there was oil all over the engine bay, turbo was spitting tabbaco and engine had major blow by.
Sad part was he bought it like this ; an auto trans an untuned ecu and a fucked turbo.
Thats all I have to share, hope you learn from your failure.
Old Nov 21, 2006 | 08:12 PM
SiR99's Avatar
did you have the car tuned on a good ems?
Old Nov 21, 2006 | 10:49 PM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">did you have the car tuned on a good ems?</TD></TR></TABLE>
i would assume no....i dont understand how this can happen because there are plenty of 300whp+ stock engine B series that dont have any problems.....i'm one of them
Old Nov 21, 2006 | 11:11 PM
qfast817's Avatar
Default Re: (Der Schistinator666)
well i had this happen to vac line poped off on the dyno
Old Nov 22, 2006 | 05:56 AM
b18sihatch's Avatar
that sucks
Old Nov 22, 2006 | 07:22 AM
Schister66's Avatar
Man U FTW
you know what this means.....time to rebuild and up the boost
momsgottagun
Oct 1, 2011 07:00 PM
NosCivic01
Oct 5, 2008 02:19 AM
b18psi
Jun 4, 2007 09:40 PM
EF'n Sedan
Mar 15, 2006 08:37 AM
UNDER PRESSURE
Jun 25, 2004 09:38 AM
