bent valves?
Old Nov 18, 2006 | 08:15 AM
boostnubII's Avatar
Default bent valves?
long story short... keyway broke...crank got stripped.... valves got bent...
here is my question...
when i bring the head into a machine shop to get a valve job... do i need to bring them in NEW VALVES or are they going to repair the ones that got bent?
Old Nov 18, 2006 | 08:16 AM
komat's Avatar
Default Re: bent valves? (boostnubII)
if its bent you will need new ones
Old Nov 18, 2006 | 08:25 AM
alpha's Avatar
Buy new valves
Old Nov 18, 2006 | 09:26 AM
boostnubII's Avatar
Default Re: bent valves? (0x64)
any idea where i can get a new set for cheap... head is 96 gsr head
Old Nov 18, 2006 | 09:33 AM
SPOOLINmatt's Avatar
im having trouble figuring out why the valves got bent from the keyway stripping, was the cam gear key way?, did the crank pulley fall off and you kept driving, i know my crank pulley fell off one time coming to a red light, it was the most awful sound ever.
Old Nov 18, 2006 | 09:36 AM
boostnubII's Avatar
car is FI btw...
Old Nov 18, 2006 | 09:40 AM
boostnubII's Avatar
Default Re: bent valves? (SPOOLINmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt &raquo;</TD></TR><TR><TD CLASS="quote">im having trouble figuring out why the valves got bent from the keyway stripping, was the cam gear key way?, did the crank pulley fall off and you kept driving, i know my crank pulley fell off one time coming to a red light, it was the most awful sound ever. </TD></TR></TABLE>
both keyways that sit on the crankshaft busted....the key for the pully and the key for the sproket thingy that runs the timing belt... when the timing belt no longer was able to turn the cams... im sure it left a total of 8 valves lowered when the pistons were still able to pump, bottom end was moving...head stopped... hence...bent valves...
thats just what the shop told me.. makes sence... but i pulled the head off yesterday and saw no signs of bent valves... not sure if that is something you can just tell from looking at it or not... but i was told i would need a valve job to correct this issue...
Old Nov 18, 2006 | 09:50 AM
purpleh22's Avatar
Have a shop check the valves to see which ones might be bent. They will have to pull the valve springs to check. You might be able to see marking on the valve relief area of the pistons, if the valves touched them- - - or not.
Old Nov 18, 2006 | 06:17 PM
underpressure02's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostnubII &raquo;</TD></TR><TR><TD CLASS="quote">any idea where i can get a new set for cheap... head is 96 gsr head</TD></TR></TABLE>
Where else but ebay. I got full ferrea valve train off there pretty dam cheap. I put all new guides, seals and locks in while I had the head rebuilt.
Old Nov 18, 2006 | 06:42 PM
chasemyhonda's Avatar
B A N N E D
I picked up a full Omni valvetrain brand new in the classified section.. springs retainers and valves for $250.
Old Nov 19, 2006 | 08:09 AM
boostnubII's Avatar
Default Re: (blindingxenon)
damn nice price... i looked at the head pretty goot... dont really look like anything is bent.... all the valves seat like nothing happened... i wonder if there is a chance that they didnt get bent when the crank got ***'d... any way to tell for sure before i take it to the machine shop tomorrow?
Old Nov 19, 2006 | 09:04 AM
komat's Avatar
Default Re: (boostnubII)
take the valves out lay them in a straight line. you can easily tell if they are bent or not if one is leaning
Old Nov 19, 2006 | 01:22 PM
shortyz21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blindingxenon &raquo;</TD></TR><TR><TD CLASS="quote">I picked up a full Omni valvetrain brand new in the classified section.. springs retainers and valves for $250.</TD></TR></TABLE>
i wouldnt trust omni to make something decent enough for any engine internals.
Old Nov 19, 2006 | 02:40 PM
turtleman321's Avatar
take the valves out put the stems on a perfectly flat surface and roll them along it.
Old Nov 19, 2006 | 03:21 PM
B e v - T e c h I n c.'s Avatar
Default Re: (turtleman321)
do you still have the stock pistons? be sure that the shop isn't blowing smoke up your ***... If they're bent, deffinately going to need new one's.
Old Nov 19, 2006 | 03:28 PM
blackeg's Avatar
wow thats bad ***, i might just go do that for myself
Old Nov 20, 2006 | 03:37 PM
B A N N E D
Default Re: (shortyz21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 &raquo;</TD></TR><TR><TD CLASS="quote">
I havent heard anything bad on the Omni valve train.. its been out for well over a year. Only thing you need to do is watch the retainers ( which you should do anyways when you are running titanium retainers.)
Virgle DeBord
Apr 15, 2018 02:44 PM
terronb20ek
16
Dec 6, 2010 01:00 AM
junk95civ
May 25, 2010 09:41 AM
boostnubII
Nov 18, 2006 10:02 AM
94eg!
22
May 8, 2006 08:07 AM
