H22 head TROUBLES???
Old Nov 20, 2006 | 09:12 AM
peakboosth22's Avatar
Default H22 head TROUBLES???
DOes anyone KNOW of a great honda head specialists in the SOUTHeast. Please respond
Curent diagnosis: A loss motion assembly (head makes a grinding noise at idle or when below 1000rpm) grinding noise reduces when engine is running above 1000rpm
Grinding started after the first pull on the dyno. Dyno sesssion stopped after the noise was detected.
Modified by peakboosth22 at 6:41 AM 11/22/2006
Old Nov 20, 2006 | 11:11 AM
turboH22Aakkord's Avatar
Default Re: H22 head TROUBLES??? (peakboosth22)
have you check out your dizzy? cause when the bearings go on those it will make a pritty nasty sqeeking/grinding noise...
Old Nov 20, 2006 | 11:53 AM
bond007's Avatar
Surprisingly I was having the same problem and it drove me crazy,like turboh22akkord
said its probably your dizzy
Old Nov 20, 2006 | 11:57 AM
Default Re: H22 head TROUBLES??? (turboH22Aakkord)
i'll check the dizzy. Is this issue common among h22?
What happens t0 the grinding noise level when the the rpms go up or down? OR does the noise level stay constant at any rpm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bond007 &raquo;</TD></TR><TR><TD CLASS="quote">Surprisingly I was having the same problem and it drove me crazy,like turboh22akkord
said its probably your dizzy</TD></TR></TABLE>
Old Nov 20, 2006 | 12:07 PM
NAH. IT IS DEFINITLY NOT THE DIZZY. TEH NOISE IS COMING FROM THE DRIVER'S SIDE
Old Nov 20, 2006 | 12:32 PM
bond007's Avatar
Could be your water pump or timing belt tensioner pulley.good luck
Old Nov 22, 2006 | 05:39 AM
Default Re: H22 head TROUBLES??? (bond007)
I will look into it. thanx
Im thinking the problem maybe the lost motion assembly a.k.a the followers
S1000RR
Dec 5, 2012 11:01 PM
worx
Mar 24, 2008 11:20 AM
rare_db2
Jul 7, 2007 08:11 PM
yubacity19
Dec 15, 2006 10:08 AM
