Turbo Trims
Old Nov 18, 2006 | 10:14 AM
90Rexx's Avatar
Default Turbo Trims
Hey guys what exactly does the trim on the turbo do? I was going to get a 57 trim turbonetics but someone told me a 57 trim wont spool until 4k rpms... my crx will be a daily driver and probobly will never se past 6 grand so i was hoping to get something that will spool around 3 grand. does that mean i need a lower trim like a 50 trim? whats the downside to getting a lower trim turbo that spools faster?
Old Nov 18, 2006 | 10:19 AM
Schister66's Avatar
Man U FTW
lower trim sizes mean smaller wheels that move less air....since there is less resistance, they spool faster, but dont move as much air
there is a trade-off
spool time<------->airflow
although there are small ways to get around it
Old Nov 18, 2006 | 10:25 AM
-Trinitron-'s Avatar
Depends on what motor is in your car, and what you want it for. A stock block is not going to move enough air to really push a big turbo. If you just want a quick pickup that peaks quick, do a .48. I ran a .54 compressor and a .63 turbine on a t3/04e. I had traction issues until about 50 mph making 300 whp. So in my case even with the larger laggier turbine it still made plenty of power down low, and was a lot of fun on the highway.
Old Nov 18, 2006 | 11:02 AM
Schister66's Avatar
Man U FTW
^^a stock block will move just as much air as a built block unless the head has been ported...the stock block will not be able to handle a bigger turbo
i had a T3/T04E 60trim .63 ar and it was great for my setup....
Old Nov 18, 2006 | 11:17 AM
90Rexx's Avatar
Default Re: Turbo Trims (90Rexx)
ok thanks for the help guys my setup is a stock d16a6 so i guess ill run like a .48 or .50 trim on a t3/t4 for quick spool. it will spool quicker but it will take longer to get peak boost? am i saying this correctly?
komat
Aug 9, 2007 02:07 PM
reaction360
Jul 2, 2004 01:31 AM
booscivic
Dec 15, 2003 07:14 PM
92lSilude
Oct 7, 2003 07:57 PM
igotyofire
May 13, 2003 11:12 AM
