WHAT AM I MISSING??
Old Nov 14, 2006 | 08:27 PM
blakacintegra's Avatar
Default WHAT AM I MISSING??
I HAVE A STOCK INTEGRA GSR AND THIS IS WHAT I HAVE SO FAR. IS THERE ANYTHING ELSE I NEED OR ANYTHING THAT WILL HELP TO CATCH MY GOAL WHICH IS ATLEAST 250WHEELHP
SC-34 TURBO
DRAG MANIFOLD
2.5INCH DOWNPIPE
TURBOSMART WASTEGATE
2.5 INCH PIPING WITH INTERCOOLER
BLITZ BOV
P28 CHIPPED WITH CROME
RC 550 INJECTORS................WHAT AM I MISSING?
Old Nov 14, 2006 | 09:24 PM
someone
Old Nov 14, 2006 | 09:26 PM
dunkd's Avatar
someone to tune it
Old Nov 14, 2006 | 09:48 PM
PrecisionH23a's Avatar
Default Re: WHAT AM I MISSING?? (blakacintegra)
You forgot to click off the caps-locked button.
Old Nov 14, 2006 | 09:51 PM
sleeprhatch's Avatar
Default Re: WHAT AM I MISSING?? (PrecisionH23a)
you forgot there is a search button
Old Nov 14, 2006 | 09:52 PM
CustomX113's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">You forgot to click off the caps-locked button.</TD></TR></TABLE>
lmao
your missing the oil feed and return lines... innercooler couplers and clamps... all teh gaskets and little random things your gonna need...
Old Nov 14, 2006 | 10:02 PM
slodel's Avatar
a weeeener
Old Nov 14, 2006 | 11:50 PM
those little random things im going to need is what im looking to find out
Old Nov 15, 2006 | 12:19 AM
i do need the gasket for the turbo to the downpipe where can i get that gasket ? if i post a pic of the downpipe can you tell me where to get it?
Old Nov 15, 2006 | 03:18 AM
Pro-Am 1934's Avatar
Default Re: (blakacintegra)
Aftermarket MAP sensor?
Boost controller?
Walbro 255 fuel pump?
Tuner?
Just a few things that are not in the list . . .
Jason
Old Nov 15, 2006 | 03:50 AM
see_our_vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blakacintegra &raquo;</TD></TR><TR><TD CLASS="quote">I HAVE A STOCK INTEGRA GSR AND THIS IS WHAT I HAVE SO FAR. IS THERE ANYTHING ELSE I NEED OR ANYTHING THAT WILL HELP TO CATCH MY GOAL WHICH IS ATLEAST 250WHEELHP
SC-34 TURBO
DRAG MANIFOLD
2.5INCH DOWNPIPE
BLITZ BOV
dump tube
oil feed/return with fittings
you might want a boost gauge and a boost controller
i'm a big fan of 1:1 rising rate fpr and a 190 or 255 walbro pump
wideband/laptop if you want to datalog and learn to tune yourself
a decent set of tires, an extra set or two of spark plugs
etc. etc.
Old Nov 15, 2006 | 05:12 AM
what are some of the good brands in FPRs, i look on ebay and there are some really cheap ones and some expensive ones, what are some brand names i should look for
Old Nov 15, 2006 | 05:14 AM
is B&M a good brand ?
Old Nov 15, 2006 | 05:46 AM
b18sihatch's Avatar
Aeromotive is really good
Old Nov 15, 2006 | 05:26 PM
Default Re: (b18sihatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">Aeromotive is really good </TD></TR></TABLE>
indeed
i wouldn't mess with b&m though, i'd shoot for an aeromotive first and foremost.
Old Nov 15, 2006 | 06:08 PM
dizzyek's Avatar
you don't need a gasket between the down pipe and turbo, wastgate and turbo, turbo and manifold. You can use gaskets on the above metioned but they won't last very long.
I Just used some rtv copper sealant. I got no leaks anywhere.
Also I would look into:
vacuum manifold
catch can
Clutch
Fuel Pump
Boost Gauge
Exhaust 2.5 inch min
Filter
Silicone couplers
T-bolt clamps
Tune
I don't think an aftermarket fuel rail and fpr are neccesary if you get a proper tune.
Old Nov 15, 2006 | 06:26 PM
Default Re: (dizzyek)
alright cool thanks a lot...what exactly is a vaccum manifold and a catch can though?
Old Nov 15, 2006 | 07:58 PM
dizzyek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blakacintegra &raquo;</TD></TR><TR><TD CLASS="quote">alright cool thanks a lot...what exactly is a vaccum manifold and a catch can though?</TD></TR></TABLE>
A vacuum maniflod allows you to run all of your vacuum lines (bov,wg,boost gauge) from a dedicated vacuum source instead of having to tee everything off existing vacuum lines in your egine compartment. It is not necesary but very convienient and functionable. They are also cheap, it was by far the best accesory purchase I made for my kit.
A catch can help to relieve the crank case preasure. The stock pcv system won't cut it in boost. I would say this should be a must purchase because they are cheap and necesary in boost applications.
Please use the search function next time there is a wealth of information on this site.
Good luck
Old Nov 15, 2006 | 09:49 PM
i found 2 vacuum manifolds on ebay that look good, which one is better golden eagle or voodoo, they both come with fittings but the golden eagle is $10 more should i go with that?
Old Nov 15, 2006 | 09:55 PM
drtysohc's Avatar
golden eagle is always a good choice
Old Nov 15, 2006 | 10:18 PM
alright ill get that one, and for the catch can i found 2 different ones on ebay also, one is like $25shipped and the other is like $70, they dont have name brands..
Old Nov 16, 2006 | 04:57 AM
is a catch can a big thing where as I should get the more efficiant one or is the catch can alright to get the cheaper one..they both look the same and come with the same parts included..on ebay type in integra catch can and 2 different ones will show up..tell me what you think..
Old Nov 16, 2006 | 10:00 AM
boostedbigguy's Avatar
what exhaust you running?
Old Nov 16, 2006 | 11:39 AM
dizzyek's Avatar
jaz catch cans are good and cheap.
A vacuum manifold is a vacuum manifold so go pick one I got a Golden Eagle cause I liked the way it looked.
Old Nov 16, 2006 | 09:06 PM
i dont have an exhaust yet, the downpipe i got came with like a 10inch piece that bolts onto it with the hole for the 02 sensor right on there and looks like an exhaust tip , so basically straight downpipe for now
