where to tap in a boost gauge??
I am installing a turbo on a 2000 honda civic si b16. I was wondering where to tap in the line to get the most accurate reading. Its a manual guage. Any pictures would help too.
thankx.
thankx.
Re: where to tap in a boost gauge?? (jrs2ksi)
pick up a vacuum manifold and run all you vacuum sources off of it. fast turbo was selling them on here a wile back for like 30 bucks i think. tap into your break booster line and you are good to go.
Re: where to tap in a boost gauge?? (95jeremie)
I don't buy into the vacuum manifold idea. It's nice if you don't have an aftermarket intake manifold with a lot of outputs, but I have a Victor X, and there are more than enough fittings so you don't need to use a vacuum manifold. I just T-ed off from my FPR to go to the gauge.
Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">It goes to the brake booster, by your master cylinder.
It isn't a good idea to "T" off your FPR line. Try to keep that un cut as much as possible.</TD></TR></TABLE>
Well, when you use a vacuum manifold, you are basically doing the same thing.
H-T White Ops
Re: where to tap in a boost gauge?? (Sprockets)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sprockets »</TD></TR><TR><TD CLASS="quote">You have cruise control. Just put the T on that vac line close to the manifold.</TD></TR></TABLE>
Damn, I was looking for that reply and didn't see it until you came along. That was going to be my $.02 to add to this.
99delsol
09-20-2006 06:57 PM
ClubSiRacer
11-12-2003 05:10 AM
Nextelbuddy
08-26-2003 10:37 AM
