Cams?
Old Nov 20, 2006 | 03:03 AM
HksHaitian's Avatar
Default Cams?
Hey guys i'm goin to be doin a turbo build pretty soon on a b16 head and i just wanted to kno wat cams are good for turbo. O yea and i'm on a budget. Thanks in advance.
Old Nov 20, 2006 | 04:46 AM
b18sihatch's Avatar
Default Re: Cams? (HksHaitian)
Stock, camshafts arent needed unless you are directly looking to tune the motor with the camshafts
stock camshafts are pretty good
Old Nov 20, 2006 | 05:26 AM
morgan@synapse motorsport's Avatar
well if u have the b16 cams use them since you're on a budget, if u have no cams at all, and just got the head, u can usually find some gsr cams fairly cheap they will net u a few more whp
Old Nov 20, 2006 | 05:40 AM
sp00led's Avatar
Default Re: (hybrdthry911)
ITR/CTR if your money is right.
GSR will work great and you can find them cheap. Actually if you look in my sig I have a set for sale that I swaped for itrs. Shoot me a PM if you want to work something out.
Old Nov 20, 2006 | 06:02 AM
HksHaitian's Avatar
Default Re: (sp00led)
O Thanks for the info guys. I'm gonna go with the itr cams. Can i use the omnipower valves and springs with these cams and still boost around 15 psi?
Old Nov 20, 2006 | 06:10 AM
what block are u using? i would look at a piston/rod upgrade before a valve/spring/retainer upgrade.
Old Nov 20, 2006 | 06:27 AM
b18sihatch's Avatar
i sendond that too, a built head is nothing without a built block, i would much rather have a head go before my block that is for sure
Old Nov 20, 2006 | 07:22 AM
HksHaitian's Avatar
i'm goin to be using a b18c1 block. I was gonna go with cp 9.0:1 pistons and eagle rods with a reblanced crank and darton sleeves.
Old Nov 20, 2006 | 07:40 AM
when u said you were on a budget i thought u meant a small budget haha
Old Nov 20, 2006 | 07:41 AM
and to answer your question omnipower will work. earl has a nice deal on supertech valve/spring/ret for 525 http://www.laskeyracing.com.
built head, sleeved built block why only 15psi?
Old Nov 20, 2006 | 08:07 AM
b18sihatch's Avatar
Default Re: (HksHaitian)
do you already have the block built, cos i wouldnt focus on the head untill the block is done.
head isnt as important as the block and if the block isnt done i would definitly focus on your block first
Old Nov 20, 2006 | 11:30 AM
HksHaitian's Avatar
Default Re: (b18sihatch)
nah i don't have the block built yet. I'm in the planning stage. I just wanted to see wat my option were and if any of my idea were possibly.
Old Nov 20, 2006 | 11:31 AM
Schister66's Avatar
Man U FTW
the block build takes presidence over the head.....
Old Nov 20, 2006 | 11:41 AM
HksHaitian's Avatar
O yea i forgot to mention i wanna try to do all this and still have my a/c and p/s. If it not possible let me kno.
Old Nov 20, 2006 | 11:44 AM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HksHaitian &raquo;</TD></TR><TR><TD CLASS="quote">O yea i forgot to mention i wanna try to do all this and still have my a/c and p/s. If it not possible let me kno.</TD></TR></TABLE>
that would depend mostly on your manifold and turbo choice
Old Nov 20, 2006 | 11:47 AM
HksHaitian's Avatar
Default Re: (that one doood)
I saw that full-race has a manifold that is a/c compatabile. It also said somthing about a 4 bolt flange for the downpipe, but most of the turbo i see have a 5 bolt flange. Which turbos are a/c compatabile?
Old Nov 20, 2006 | 12:15 PM
Topdawgg's Avatar
GSR cams are good
CTR/ITR cams are good and you dont have to change rest of the valvetrain
Old Nov 20, 2006 | 03:08 PM
HksHaitian's Avatar
Default Re: (Topdawgg)
Wat psi is the stock vavletrain good up to?
Old Nov 20, 2006 | 03:26 PM
Topdawgg's Avatar
guys are makin 500+ on stock valvetrain
Old Nov 20, 2006 | 05:11 PM
HksHaitian's Avatar
So i can get new oem complete vavletrain, itr cams, and itr intake manifold and my head would be good to go?
Old Nov 20, 2006 | 05:20 PM
if the head has no valvetrain at all i say dont put oem in, just build it. if u already have oem stick with that unless u plan to make over 400whp
Old Nov 21, 2006 | 02:52 AM
HksHaitian's Avatar
O ok got ya. My main concern right now is the block. I gotta sleve it if i wanna make over 400 right? And i can still have a/c and p/s? Plus i don't understand the part about the 4 or 5 bolt downpipe flange.
Old Nov 21, 2006 | 06:37 AM
how much power do u want to make. most likely the turbo youll get will have a 4 bolt flange. either way u can get a downpipe fabbed up for it no prolblem
Old Nov 21, 2006 | 07:22 AM
HksHaitian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrdthry911 &raquo;</TD></TR><TR><TD CLASS="quote">how much power do u want to make. most likely the turbo youll get will have a 4 bolt flange. either way u can get a downpipe fabbed up for it no prolblem</TD></TR></TABLE>
I wanna make around 400-500 realiblty horsepower, and i've decided not to go with a/c or p/s.
Old Nov 21, 2006 | 07:28 AM
slow poke's Avatar
I wanna make around 400-500 realiblty horsepower, and i've decided not to go with a/c or p/s.</TD></TR></TABLE>
Just get the GSR's then and save the extra 100-200$ for tuning. I see NO need for any ITR or CTR cams with your goals and setup. I make over 600 on GSR cams as have many, many others.
