reusing valve guides
Old Nov 21, 2006 | 07:28 PM
SoOHiGH's Avatar
Default reusing valve guides
i got aftermarket valves, springs, cams, retainers, new OEM seats, new OEM seals, and reusing keepers.
My quiestion is, can i reuse my valve guide?
edit: the only way a valve guide can get damaged is if a valve bent right? so it should be ok to reuse my guides ???
Old Nov 21, 2006 | 07:35 PM
EG-6SRNAC's Avatar
Default Re: reusing valve guides (SoOHiGH)
That depends on how much wear the original valves wore into the guides i would measure it then decide if you want to reuse them or not
Old Nov 21, 2006 | 08:47 PM
SoOHiGH's Avatar
Default Re: reusing valve guides (EG-6SRNAC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG-6SRNAC &raquo;</TD></TR><TR><TD CLASS="quote">That depends on how much wear the original valves wore into the guides i would measure it then decide if you want to reuse them or not</TD></TR></TABLE>
how would i measure them? with what tool? because i dont think a caliper would fit ?
Old Nov 22, 2006 | 03:40 AM
NJIN BUILDR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoOHiGH &raquo;</TD></TR><TR><TD CLASS="quote">
how would i measure them? with what tool? because i dont think a caliper would fit ?</TD></TR></TABLE>
The machine shop that's doing the valve job can do it for you.
BLacK FirE
May 24, 2006 05:30 PM
turbotime
Mar 31, 2006 06:21 AM
thaiphob
Dec 2, 2005 01:15 PM
BLK99VTECR
Mar 1, 2004 05:13 AM
andrewasf77
Feb 23, 2004 10:15 AM
