b16 with sc34
Old Nov 15, 2006 | 01:27 PM
hybridpatient95's Avatar
Default b16 with sc34
my first ever turbo setup looking to make 300-350whp on stock motor.
b16
lsd tranny
sc34 turbo .60 .63
ramhorn manifold
tial 38mm wastegate
2.5in piping
3in dp & exhaust
680cc injectors
255 intank fuel pump
greddy type s bov
thinkings of getting thicker headgasket, and headstuds
going to be tuned on Crome. how much psi should i run to achieve this goal? i was thinking of running 12psi this is my DD. the motor is in a Delsol chasis.
here some pics. (camera phone)
i got couple more pics. just need to email them to myself
Old Nov 15, 2006 | 01:46 PM
VtecCarHauler's Avatar
Default Re: b16 with sc34 (hybridpatient95)
do you have B16 a or b. Headstuds and thicker headgasket won't hurt, cheap investment. Check C-speedracing.com to get a compression check. Your set-up is fine, I would look into an oil catch can if u do not have one, something like Endyn look up(theoldone.com) FPR can help too. Along with some cam gears. All cheap parts that can give you more power and durability. Exact boost psi I cannot tell it will depend on how your parts work together. On that turbo I will guess between 14-18psi to reach 350whp.
Old Nov 15, 2006 | 04:40 PM
Default Re: b16 with sc34 (VtecCarHauler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecCarHauler &raquo;</TD></TR><TR><TD CLASS="quote">do you have B16 a or b. Headstuds and thicker headgasket won't hurt, cheap investment. Check C-speedracing.com to get a compression check. Your set-up is fine, I would look into an oil catch can if u do not have one, something like Endyn look up(theoldone.com) FPR can help too. Along with some cam gears. All cheap parts that can give you more power and durability. Exact boost psi I cannot tell it will depend on how your parts work together. On that turbo I will guess between 14-18psi to reach 350whp.
thanks for your input. whats your setup?
i have a BONE STOCK b16 motor.
anymore opinions?
Old Nov 15, 2006 | 05:21 PM
B.'s Avatar
B.
400 HP Club
with a good motor and tune those numbers can be hit with 10 psi easy..
Old Nov 15, 2006 | 06:01 PM
b18sihatch's Avatar
low end 10 high end 15 but depends on how well your setup responds
Old Nov 15, 2006 | 06:15 PM
good info guys.
any other cheap insurance investments i should buy
Old Nov 16, 2006 | 04:01 AM
LostSolVTEC's Avatar
Default Re: (hybridpatient95)
new headstuds are worth their weight in gold on a stock motor in my opinion. a set of GSR or ITR cams and adj cam gears are a nice addition too
Old Nov 16, 2006 | 05:10 AM
Default Re: (LostSolVTEC)
yeah I forgot the cams, GSR or ITR's. I have seen the dyno graphs numerous times. The GSR's make at least 25-45whp over oem B16's. Checkout evans-tunning.com and study the dynographs. That is what I do when I am building a new setup.
Old Nov 16, 2006 | 05:19 AM
thats what ive been doing, just i havent been paying attention to the cams. thanks for the advice ima have to hunt down some cams
Old Nov 16, 2006 | 05:37 PM
finished up my piping today. hopefully i can fab up a dp this weekend and do the drain line. and start this fool
Old Nov 16, 2006 | 06:16 PM
my setup https://honda-tech.com/zerothread?id=1793282
Old Nov 16, 2006 | 06:35 PM
dam nice setup!
Old Nov 16, 2006 | 10:28 PM
IceySC's Avatar
is that a peakboost manifold? nice
Old Nov 17, 2006 | 04:23 AM
Default Re: b16 with sc34 (IceySC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IceySC &raquo;</TD></TR><TR><TD CLASS="quote">is that a peakboost manifold? nice</TD></TR></TABLE>
no i dont think so. i think its just a regular ramhorn
Old Nov 21, 2006 | 02:23 PM
high_revs's Avatar
buy me lol
dutchCRX
Nov 21, 2013 05:48 AM
lukerc45
Nov 23, 2007 09:45 PM
KiNG $h!t
Oct 6, 2004 04:53 PM
DubyaAye
Apr 17, 2004 09:03 AM
