225 BF Drag radials..
To all of the guys running the 225 br Drag radials... I wanted to run 205/50R15's in the summer but if I can get 225's under there then that would be even better!
What is the size of your tires/rims? What Rims are you using?
What is your camber at?
I have a camber kit that fits my 205/40R17's perfectly ( can not remeber the camber value....) Will the 225's fit? (Sorry if it is a silly question...)
Thanks
Derek
Thanks
Derek
Re: (komat)
15"x7" rota gt3 with the 225/50/15 bfg fits, but I had to jack the front of the car up a little to make sure everything cleared. I also have the inside of my front fenders trimmed a little as well. I also run 205/40/17 regularly with even tire to fender gap to give you an idea of how low it is. I raised up the front probably 1/2" to 3/4" of an inch to not be scared about driving it on the street.
Re: (livinlow)
95 GSR, no camber kit, eibach prokit
225/50/15 BFG radials on 15x6.5 rota attacks.
Rubbed the inner fender on lock to lock turns, and rubbed a bit on hard bumps ... other than that it wasn't bad at all.
A friend of mine had them on his 97 DX coupe on 15x7 rota gt3's, omnipower camber kit, lowered enough so there was no fender gap at all on ground control coilovers ... rubbed a bit more than mine, but nothing crazy.
Re: (blindingxenon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blindingxenon »</TD></TR><TR><TD CLASS="quote">Ive wanted to put some 225's on my car. i doubt they would fit on a 6" or 6.5" wide rim</TD></TR></TABLE>
i doubt the 6" but def a 6.5" rim...i have on em my stockers :-p nice thick sidewall too...just gotta watch out for curbs...
I run 225/45/17 on my 17" wheels. 7.5" wide wheel. lowered 1". Rubs badly anymroe then 80% turn. Hooks good tho. Have run 12.02's in a 2650 lbs weight Integra.
Re: 225 BF Drag radials.. (jitterbox2)
i run 225/50/15 on stock itr wheels. cut a few 1.7 sixty foots with them and consitant low 1.8's. but yea they only run when fully locked
