question about a cast manifold I just bought....
http://cgi.ebay.com/ebaymotors...ZWDVW
Just bought one of those manifolds for a budget build and noticed the 38mm wastegate hole is a little smaller then the actual wastegate.
Will this effect boost creep?
Should I go to a machine shop and get it bored out a little bit?
Thanks for any help
Thanks for any help
i made 330/260 on that mani, used a 35mm to make 300/255 and had NO boost creep or spiking issues.
Only issue i had with the mani is the wg will hit the head (for vtec heads, ok for non vtec) and the gap between the #2 & #3 runners is so small theres barely any room for the dip stick
TB123
02-29-2008 08:08 PM
