turbo question.
Old Nov 19, 2006 | 02:18 PM
civic_66's Avatar
Default turbo question.
well i've decided i'm not going to be doing a swap. im going to keep the b16a2 thats in my eg right now and go from there. first off i want to start with a turbo. what would you guys recommend? i'm thinking of t3/t4. my goal is to lower the compression so the car is capable of 20 PSI. and my horsepower goals are 400+ WHP. so basically my question is which turbo do you think is right for my project? and what kind of prices should i be looking for? thanks
Old Nov 19, 2006 | 02:29 PM
BoostedEG6's Avatar
Default Re: turbo question. (civic_66)
you have alot of research ahead of you
You are going to need pistons, rods, sleeves, a great turbo kit and great EMS
Old Nov 19, 2006 | 02:31 PM
Boner_Ben's Avatar
Default Re: turbo question. (BoostedEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 &raquo;</TD></TR><TR><TD CLASS="quote">you have alot of research ahead of you
You are going to need pistons, rods, sleeves, a great turbo kit and great EMS </TD></TR></TABLE>
You dont need sleeves, but with a set of pistons and rods you'll be set as far as the motor goes.
Old Nov 19, 2006 | 02:48 PM
BoostedEG6's Avatar
Default Re: turbo question. (Boner_Ben)
trust me I know he doesnt need sleeves...... I ran stock sleeves for awhile also but I think its smarter to go ahead and do them while the motor is out and people are now doing sleeves for like ~850 shipped
I know I wish I would have done them the first time I built my motor...... but then again it all comes down to his cash flow and how much he can spend on everything
Old Nov 19, 2006 | 02:51 PM
civic_66's Avatar
thanks guys. i've seen some guys running 35 PSI. how can there engine withstand that? is the key thing here runnign a extremely low compression ratio?
Old Nov 19, 2006 | 02:56 PM
BoostedEG6's Avatar
people running 35psi have more than likly had their blocks resleeved and have a good tuner... tunning is the key to making a motor last and people run 30+psi on 9.5 and higher compression
Old Nov 19, 2006 | 02:57 PM
B e v - T e c h I n c.'s Avatar
That's not hard to achieve, like everyone said. Pistons and rods. if you don't do the sleeves, be sure to put a block guard in. and deffinately be sure to have to block bored like .010 over to ensure that the cylinders and round and straight. Then get a good turbo kit.. (full-race is a good one) and a good fuel system and fuel managment. you'll be good to go... Good luck
Old Nov 19, 2006 | 03:02 PM
civic_66's Avatar
Default Re: (B e v - T e c h I n c.)
for my first turbo i was thinking of t3/t4. i've been takkign to acouple guys and they said i could run 9 PSI on my b16 with all stock internals. now once i low ther CR would this turbo be able to perform over 450+ hp? or should i be looking into a different turbo?
austinwith96civic
Jul 26, 2009 09:12 PM
Jedi Jake
Feb 20, 2007 06:40 PM
Itbdennis
Jul 28, 2005 03:26 AM
boosted lude
Mar 21, 2005 03:43 PM
Outkast_CL9
Jul 5, 2004 05:50 AM
