compression test results
Old Nov 4, 2001 | 07:48 PM
Jesse H's Avatar
Default compression test results
195 in cylinders 1, 2
210 in cylinders 3, 4
*scratching head*
Old Nov 4, 2001 | 07:58 PM
PureTeg420's Avatar
Default Re: compression test results (Jesse H)
looks good to me. i had 210 across the board with only 7k miles so you should be happy..
Old Nov 4, 2001 | 08:28 PM
Jesse H's Avatar
Default Re: compression test results (PureTeg420)
oh ok. I just thought that they needed to be the same across the cylinders.
Old Nov 4, 2001 | 08:37 PM
905_S2K's Avatar
New User
Those #'s look good, did you do a wet test as well? What was percentage in difference compared to the dry test?
Old Nov 4, 2001 | 08:59 PM
FSTASNTZ's Avatar
Do not worry about the difference unless two adjacent cylinders are more 10% off.
Before my rebuild, mine read:
180 210 120 170
After:
280 285 275 280
Turned out the intake valves were not sealing...
Jason
liquidzorch
Sep 13, 2013 07:33 PM
SilkyJohnson
13
Feb 15, 2011 05:54 PM
humboldt_skim
May 31, 2008 08:18 AM
B18PoweredCivic
May 29, 2003 03:57 PM
Propulsion
Jun 5, 2002 11:48 PM
