Changing pistons...
Old Nov 8, 2001 | 06:42 PM
teg92's Avatar
Default Changing pistons...
How many people here have changed pistons without touching the cylinders (i.e. direct replacement, no boring, surface honing)? Realistically, is it that bad of an idea on a low milage engine (62,000miles)? Thanks
Old Nov 8, 2001 | 07:09 PM
non-VTEC's Avatar
Default Re: Changing pistons... (teg92)
i did it on my engine with about 65-70k.......using standard bore ITR pistion and new rings. i simply used a glaze breaker to lightly "clean up" the cylinder walls a little. most people will say it's not the best way to do it but it worked out ok for me.........
Old Nov 8, 2001 | 07:31 PM
teg92's Avatar
Default Re: Changing pistons... (non-VTEC)
Cool... by any chance do you know what the JDM ITR pistons bring the CR to in an B18A1? The price on this board seems too good to pass up!!
Old Nov 8, 2001 | 09:18 PM
Vtec integra's Avatar
you'll probably have to hone it
just lightly though
its not that hard you can do it yourself
Old Nov 9, 2001 | 03:08 AM
non-VTEC's Avatar
JDM ITR pistons will bring your CR up over 11:1
not exactly sure. calculating the accual CR is not as easy as it may seem.
Old Nov 9, 2001 | 05:39 AM
pregunta's Avatar
I've done it. It was no prblem. Just go slow and take your time.
Old Nov 10, 2001 | 06:02 PM
Comp97GSR's Avatar
JDM ITR pistons in a GSR head up CR to 11.4-11.5. I will be doing this soon so that is how I know.
Good Luck
Old Nov 10, 2001 | 06:31 PM
RStoR's Avatar
I calculated it out and your compression would be 11.14 with OE headgasket.
Old Nov 10, 2001 | 11:45 PM
why not throw in some b16 pistons with a gs-r head
it'll bump the compression up to about 11:5:1 and will
be a little cheaper than jdm type r pistons
Old Nov 12, 2001 | 06:04 PM
Halo's Avatar
Default Re: Changing pistons... (Vtec integra)
he doesn't have a GSR head
xQB21x
Dec 18, 2009 04:54 AM
mac_24_seven
11
Aug 7, 2007 02:31 PM
SOLORIO
12
Feb 28, 2007 03:17 PM
88hondahatch
10
Sep 19, 2003 12:03 PM
