gTECH
Old Nov 5, 2001 | 12:13 PM
Muckman's Avatar
Moderator in Chief
Default gTECH
I wanted to start a discussion about the gTECH units.
My best 1/4 mile with a gTECH unit is 14.89 @ 99.7. I post the 14.89 as part of my sig. I get alot of IMs concerning my trap speed. I agree 99.7 is sort of high for a 14.89 sec run. But I do believe the 14.89 is accurate. Heres why:
My friend who owned the gTECH and who drove a S2000 at the time, took me to the track alot. He ran a few track runs with the gTECH running, and every run it was within a .001 sec + or - of the ET. I can't remember if the trap speed was accurate or not.
To date, my best track run is only a 15.11 @ 94. Thats quite a difference from 14.89. On the street with the gTECH I was able to choose my road surface and therefore didint get any wheel hop. At track tho, I always get wheel hop. Plus with a gTECH you can go when your ready and your not nervous like you maybe at a track with everyone staring at you.
I feel that gTECH results are what the car and driver are really capable of under ideal conditions. However that may not be replicable in the real world such as on a track. Which one is the more accurate reading in this case?
So what do you guys think about the gTECH? Do you respect it? Can I legitemately post 1320 times from a gTECH? Or would that make me a bad honda-tech member?
Old Nov 5, 2001 | 12:17 PM
Veritas-Aequitas's Avatar
Grumpy Old Man
Default Re: gTECH (Muckman)
How much does the gTECH unit cost?
Old Nov 5, 2001 | 12:23 PM
Muckman's Avatar
Moderator in Chief
Default Re: gTECH (ReBornGSR)
http://www.gtechpro.com
$140
Old Nov 5, 2001 | 12:24 PM
Chris's Avatar
it WAS free with purchase of BFG tires at America's Tire. I used a friends and can say I am amazed at the accuracy. It is sweet!
Old Nov 5, 2001 | 12:25 PM
JL 74's Avatar
25 Year Member
FREE, if you are in the market for new tires (with the purchase of Goodyear Tires, or Bridgestone, can't remember). Check Motortrend
Old Nov 5, 2001 | 12:36 PM
Grumpy Old Man
Default Re: gTECH (Chris)
Well 140$ is a lot but if you look at it like this...$5 for a friend to use...140/5=28...But who wants to use it just once? I mean at least 2 times a friend right? So 14! I have 14 friends with cars!!! I just got myself a free gTECH without buying any tires
[Modified by ReBornGSR, 4:36 PM 11/5/2001]
Old Nov 5, 2001 | 12:52 PM
Jesse H's Avatar
GTech is consistent and ok as far as accuracy for the ET. Reason the MPH is kinda off is because the GTech measures the MPH as you cross the line.
At the track they measure the average of the last x feet.
Old Nov 5, 2001 | 02:33 PM
Muckman's Avatar
Moderator in Chief
Default Re: gTECH (Jesse H)
Reason the MPH is kinda off is because the GTech measures the MPH as you cross the line. At the track they measure the average of the last x feet.
I did not know that... but that makes perfect sense.
Thank you
[Modified by Muckman, 6:34 PM 11/5/2001]
Old Nov 6, 2001 | 03:30 PM
96whitels's Avatar
New User
Thats funny cause when i g-teched my car the fastest time i could get was 16.1 but at the track i ran a 15.7
Old Nov 6, 2001 | 03:58 PM
Stephen's Avatar
Default Re: gTECH (96whitels)
The GTECH may not start "counting" till you've moved a couple inches, enough to throw the G-force to >.05G or something. Basically what I'm trying to say is that at the track, the clock starts when you "break the laser"...the Gtech starts when you reach the "critical G-force". They may or not be at the same time. Given that, you can't directly compare a track and a Gtech 1/4 time.
It IS very consistent though
Old Nov 10, 2001 | 09:08 AM
Muckman's Avatar
Moderator in Chief
hah that is odd.. ive never heard that before.
Old Nov 10, 2001 | 09:13 AM
mr2's Avatar
mr2
ummm g tech.. is it hard to install?
Old Nov 10, 2001 | 11:30 AM
Ricehornet's Avatar
Yah, the speed at the track i think is your avg speed through the last 60ft or somthing. Because the track doesnt have a speed detecting device, just a series of sensors that start and stop timing.
GTECH i think can be useful for tuning because it allows you to measure runs....sure it may not be the same as a track run, but then again, you still see descrepencies from track to track for the same reasons, pavement, alt, wind direction, and grade. If you GTECHed on the same road over and over again it will be a good indicator for improvement.
Old Nov 10, 2001 | 02:32 PM
smerk's Avatar
New User
The GTech is consistent but not consistent with the dragstrip. It is a good to tool to use to compare your own GTech times to see if there are any improvements in driving and mods. If you post a GTech 1/4 mile time, I think you should specify that it is a GTech time. Otherwise you will have people calling it BS (usually for the high trap speed). BTW with your 94mph trap speed at the strip, you can definitely hit a high 14, you just need to get a good launch.
Old Nov 10, 2001 | 02:43 PM
drumsy's Avatar
New User
Default Re: gTECH (white eg)
All it does is suction cup to your windshield from the inside and plug into your cigarette lighter. You do have to suction it using a built-in balancing program, so it can accurately measure g-forces.
Old Nov 10, 2001 | 02:55 PM
lucas569's Avatar
Default Re: gTECH (drumsy)
my friend let me use one and it was within tenths in the 1/4 mile compared to my actual track times but the trap speeds were higher. why? cause the g-tech is an accelerameter. doesnt start measuring till it feels the car move.
Old Nov 10, 2001 | 05:21 PM
intekragsr's Avatar
GET THE APEX-I REVSPEED METER. IT DOES ALL THE SAME THINGS AS GTECH, BUT LOOKS A LOT BETTER AND GRAPHS, AND DOES ALL THE KOOL THINGS. and its digital
98h22
Jun 21, 2009 01:34 PM
Machine1
Jan 17, 2005 01:00 PM
HaTcH_BmX
Jul 18, 2003 03:34 PM
el arbi
Apr 29, 2003 07:19 AM
