engine light came on..
Old Nov 9, 2001 | 10:31 AM
97GSR's Avatar
Default engine light came on..
What should i check when your engine light comes on? i was just driving and it came on last night, but i dont see or feel any problems.
Old Nov 9, 2001 | 10:45 AM
LostGsr's Avatar
Default Re: engine light came on.. (97GSR)
If its the check engine light, then pull the code and see what causing it. Go here for instruction on how:http://www.c-speedracing.com/faq/06.html and then here to see what the code mean:http://www.c-speedracing.com/faq/05.html If its the maintance light, its just a reminder for schedule maintance ntohing to worry about.
Go here for how to reset it:http://www.c-speedracing.com/faq/01.html
[Modified by LostGsr, 11:52 AM 11/9/2001]
Old Nov 9, 2001 | 11:08 AM
ANACC2NV's Avatar
New User
Default Re: engine light came on.. (LostGsr)
humm same thing happened to me a month ago and i left it for a week and then it shut off on its own.... who knows..my car was runing fine to at the time.
Old Nov 9, 2001 | 04:41 PM
97GSR's Avatar
ok i checked it out and it blink to be 67..so its
Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system
what does this mean? do i need a new cat?
is this something that need immediate attention?
[Modified by 97GSR, 5:43 PM 11/9/2001]
Old Nov 9, 2001 | 05:23 PM
LostGsr's Avatar
Did you by any chance gut the cat or remove it altogether and replaced it with a test pipe? If not, reset the ecu and see does it come back. Also did you or someone else worked underneath the car recently? Its possible that one of the two o2 sensor's connector came loose. Also do you smell sulfur? I heard its a sign of a bad cat. If none of those work, and you still throw the same code then you might need a new cat. But its hard to believe that a cat will go bad on a 97 unless you modified the car and didn't tune it correctly.
Old Nov 9, 2001 | 05:28 PM
97GSR's Avatar
no its the original cat untouched. i havent work on the bottom of the car for a while now and it just came on when i was driving yesterday.
so is it for sure the cat? how much would a new cat run me?
also is it safe to drive for now?
Old Nov 9, 2001 | 05:33 PM
gsr stuie's Avatar
97 gsr check your o2 sensor, sensor plug, sensor if be.
Sounds like either something is disconnected or cut, or the sensor has failed
Old Nov 9, 2001 | 05:42 PM
LostGsr's Avatar
I believe if you throw a cel light, you car will run in a limp mode to protect it. So no Vtec. Reset the Ecu and see if it returns.
Old Nov 11, 2001 | 02:50 PM
97GSR's Avatar
now that i drive, i smell a burning smell..or like my car is burning or its running rich. does this relate to code 67 at all?
Old Nov 12, 2001 | 05:29 AM
gsr stuie's Avatar
check your cat.
Old Nov 12, 2001 | 06:30 AM
samagon's Avatar
is your car the same as your name?
I only ask because there was a waranty notice I got about 2 months ago, letting me know that the cat was warantied by acura for 150k miles. I don't have the piece of paper in front of me, but you should go into your dealer and ask what it is for.
pindented
Jul 11, 2013 11:07 AM
blaze.1
Aug 3, 2009 10:28 AM
eg686
Apr 18, 2003 01:01 PM
laurat
Oct 14, 2002 12:54 PM
tuco_ruiz
Sep 15, 2002 05:24 PM
