zex install
i have a 93 integra with a b16a in there i am going too put the zex kit in this week and i need some help i have two questions. which colored wire on the tps do i use that goes too the zex unit and how far do i put the fogger from the throttle body. and is there anything else that i need to know if there is please let me know thanks
well hey wus sup okay im darwin
the zex setup is really easy to install there are three wiries you have on the purple box (brain) black wire goes to ground , red is to pos battey terminal and white will go to the tps sensor.. to find the signal off of the tps do this make sure every thing else is hooked up ( red and black wire ) and get a nedel and poke at each wire one by one but each wire when you poke it make sure the car is turned to the on position but not runing grab the white wire wrap it around the nedel and poke each wire but each wire you poke open the throttle body all the way till you here a click from the nitrous box or brain and that it and after you finished make sure you double check over your work thats it ..
have fun email back after your finished i gess and tell me how it went if you have any other questions drop me an email some time at
greasemonkay@asianavenue.com or dgreaseme@yahoo.com
VolkswagenWHO!!!
Jan 4, 2006 01:34 PM
TABIAS
Nov 29, 2003 03:57 PM
