ECU for an LS?
Old Nov 9, 2001 | 07:27 PM
SoSoJeff's Avatar
Default ECU for an LS?
Which ECU should i get for my 94 LS?
So far my mods are H/I/E, port polish, 3 angle valve job, milled,
ported matched manifold & tb.
Old Nov 9, 2001 | 07:52 PM
teg92's Avatar
Default Re: ECU for an LS? (SoSoJeff)
I'm interested in hearing about ECU options for built LS's as well
Old Nov 9, 2001 | 09:05 PM
Halo's Avatar
Default Re: ECU for an LS? (teg92)
you should get a 94 P75 and chip it. I offer programs for the P75, bypass knock sensor, higher shift points etc...........for $90 cheers
Old Nov 9, 2001 | 10:01 PM
PaChiLa Leader's Avatar
Default Re: ECU for an LS? (Halo)
this is ******* great...
i have a 2k teg which is OBD2B, recently bought a 95' OBD1 P75...
Anyways, i think i would need you to chip it for me..
so what can you do with it.. red line, speed limited..etc?
Old Nov 9, 2001 | 10:10 PM
Halo's Avatar
Default Re: ECU for an LS? (PaChiLa Leader)
look in the classifieds. I can also get OBD2 to 1 harness's, For the P75 we can either move your rev limit to 8700 or 9100 and adjust the fuel and timing curve to accomodtae big camsi.e...Crower 62404 and headwork
Old Nov 9, 2001 | 10:17 PM
cool~ this is great man..
so how much can you get me for the harness?
you know the harness is the problem for me not to running with my OBD1 ECU right now.. coz i dont' have it and it's expensive out there .. like 235 SHipped..
PooH~ well if you can get me a good deal of chip and harness let me know..
but i am not planning to do it right now though.. coz spent lot of money on Snowboarding bypass.. ahhaha keep me posted.. thanks
Old Nov 10, 2001 | 12:21 AM
Halo's Avatar
I sent you an email
Old Nov 10, 2001 | 01:56 AM
B18C-EJ1
Guest
Posts: n/a
Knock sensor huh? Really..... higher shift points?
Nothing personal Halo, but if you chip ECU's then you should know that the LS doesn't have a "Knock Sensor", and I think you're refering to removing or raising the rev-limiter to allow higher rpm's.
Old Nov 10, 2001 | 02:02 AM
Default Re: ECU for an LS? (B18C-EJ1)
[/QUOTE]
yeah i was thinking the knock sensor thign too.. coz i know if i go LS/Vtec i will need the knock sensor ( GSR)
well maybe he just messed up with the GSR thing..
no worries
Old Nov 10, 2001 | 09:13 AM
non-VTEC's Avatar
Halo: can you make just a stock LS program with slightly extended rev-limiter (7700rpm) and increased idle to about 900rpm? if it's possible e-mail me so we can discuss this more......
p.s. were you the one who told me about the Si Industries valves? i need the contact information about those again........
-[uSa]-Defcon_07
Jul 14, 2007 01:43 PM
SIsohcvtec
Jul 6, 2004 09:37 AM
DjFreeze
Nov 3, 2002 06:33 AM
