brake problems help please
Old Mar 15, 2004 | 02:45 PM
integraGSR213's Avatar
New User
Default brake problems help please
I took my tranny off and installed everything back fine. I notice that after I installed everything when I press the brake sometimes it would make a rumbling noise from the right side. I don't know what it is. I checked all the screws and bolts around the brake. I did remove the pads when I was removing the axle, does it matter if I but the old pad back in. I want to figure this out but I am stumped can someone please help.
thanks
Old Mar 15, 2004 | 02:51 PM
BolivianDc2's Avatar
Default Re: brake problems help please (integraGSR213)
are the calipher bolts on tight?
Old Mar 15, 2004 | 02:53 PM
New User
Default Re: brake problems help please (BolivianDc2)
yes they were a little but i tighten the bolts already. I thought that fixed the problem but it still makes rumbles, but not as much.
Old Mar 15, 2004 | 02:55 PM
SuzukaBlueAP2's Avatar
I don't know why you pulled the brakes and stuff off to take the axle out..but that's neither here nor there...
When you hear this "rumbling" noise, do you feel any vibration with it ? Or is it just noise ? And you only here it sometimes...it's not everytime you hit the brakes?
Is it when you are turning ? going straight ?
Old Mar 15, 2004 | 03:11 PM
New User
Default Re: brake problems help please (ScreaminTeg)
i don't know why I took the brakes off also...I realized it after I took it off that I didn't need to. Yes I feel a vibration it is not hard but it does vibrate when I press on the brakes. I can't really hear if there is noise when I am driving the car but I feel it vibrate. I feel it when I step on the brakes almost everytime. It happens when I am braking going straight, I don't really feel it on a turn.
btw thanks for the help
Atomic1
Jun 1, 2011 05:19 PM
lowered94accord
May 14, 2006 01:39 PM
GUNNER666
Oct 19, 2004 06:45 AM
FortunateFool.
May 21, 2004 06:09 PM
