front camshaft seal
front camshaft seal
i purchased two new front cam seals and they dont seem to fit correctly.
i double checked and they are the right ones. does anyone know the correct way to install front cam seals
Re: (red Teggie)
No.. i believe you do take them out. Seeing as how he said he bought two of them... seals that is.
there is only one cam plug, since the other side has a distributor on it.
In-N-Out Burger
Re: (red Teggie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red Teggie »</TD></TR><TR><TD CLASS="quote">No, you don't take out the camshaft to install the cam seal.
Just take off the valve cover, take out the piece that holds the cam seal, clean the surface well, put a dab of hondabond on the new seal, then put everything back together.
I did the same thing a while ago, and no leaks so far. Might wanna replace the valve cover gasket, and the spark plug hole grommet thingy while you are at it.
by the way, why did you purchase two?
:: on you! The seal you are talking about is the cam plug. The cam seals come in TWO (2) and you need to take out the camshafts to install them. THE CAM PLUG on the other hand (see picture of STR cam plug above, is the one neareast the distributor.
NRG
NRG
Re: (NightRider-gsR)
I bought a billett one for mine, it looks tight. I was told that this seal leak was a common problem. the billet is supposed to last alot longer. just remove your valve cover and the two bolts holding down the cam seal.
Re: (red Teggie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red Teggie »</TD></TR><TR><TD CLASS="quote">Are you saying you have to take out the camshaft to replace the cam seal?
Have you ever even done it?
You ARE talking about this, right? (I know it's not the stock, but it's the only one I could find)[/img]</TD></TR></TABLE>
1. Yes
2. Yes
3. No
1. Yes
2. Yes
3. No
Re: front camshaft seal (blackdude)
my cam "plug" is leaking also .. i just ordered a STR should be in tommorrow or fri .. my new oem one lasted only about 30k miles it seams ... better luck with the STR i hope
Re: front camshaft seal (zilverz)
no leaks so far with my STR cam plug. it is tight plus i put some rtv on it to prevent any leaks. you will like it and it looks great!
Re: front camshaft seal (MAV3RiCK478)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAV3RiCK478 »</TD></TR><TR><TD CLASS="quote">no leaks so far with my STR cam plug. it is tight plus i put some rtv on it to prevent any leaks. you will like it and it looks great! </TD></TR></TABLE>
awesome i picked up some hondabond so hopefully illl stop losing all this damn oil (;
DC2NING
06-23-2004 02:38 PM
