JDM b16 Cams in a b18c1
Re: JDM b16 Cams in a b18c1 (riceball777)
you folks don't know what you guys talking about nothing personal
as far as oem cams goes....
>>gsr cams is low compression which is very good for turbo specifications
>>jdm b16 is good for all motor, nos specifications due to the fact that's the intake cam is bigger than any other oem cams
>>type r is the same lube but the only differrence is the intake cams cause like wat i said earlier b16 is intake side is bigger than others.
>>all motor go with ctr or itr
>>turbo b16,b18c1, ls cams
