Rasing Compression
Old Mar 15, 2004 | 11:05 PM
JFG Kevin's Avatar
Default Rasing Compression
I remember readin somewhere.if you remove some head gasket or valve gasket....it will rasie compression...if so..which one...and is it safe?
Old Mar 15, 2004 | 11:08 PM
LSTEG96's Avatar
Default Re: Rasing Compression (aznstyler119)
ur gonna wanna completely remove both... that will bump up your compression a SHITLOAD!! and ur car will rip!
Old Mar 15, 2004 | 11:12 PM
Slain's Avatar
its removing the middle peice of the stock headgasket. I'd rather buy a thinner headgasket. or have the head milled a little.
Old Mar 16, 2004 | 09:29 AM
JFG Kevin's Avatar
Default Re: (Slain)
Is this safe?
Old Mar 16, 2004 | 09:36 AM
Chaos69's Avatar
Default Re: (aznstyler119)
It is safe, but not removing the layer from your current headgasket... Buy a new one, then do it.
Or you can buy a thinner head gasket, from Mugen for example to raise yoru compression .4
If your head and block do not meet each other fairly flat however, you risk a head gasket leak.
What mods do you have done? Is it even worth it for you to go through this trouble?
Old Mar 16, 2004 | 10:04 AM
JFG Kevin's Avatar
Default Re: (Chaos69)
Haven't done much mods just a CAI rite now...but i should be gettin gmy settlement check soon...and i'm planning to get headers and exhaust...then cams..basic build up process...will the high compression help my power at out? with these mod?
Old Mar 16, 2004 | 10:13 AM
Slain's Avatar
you should take a look in the all motor forum. alot of good info there. just soak up as much information as you can then when your comfortable with what you know get what you need.
As with the build up everything works in conjunction with each other. every little bit adds up but do it right the first time and you'll be a happier person in the end
Old Mar 16, 2004 | 11:59 AM
ThePro's Avatar
Hehe. In March's issue of Turbo magazine it has an interview with a old drag racer. He mentions that he used to have a little gas powered scooter of some sort.
He wanted more power and heard you have to mill the head, but he didn't have money to go to a machine shop (he was 11) and he didn't have any way to do it.
So his older friend and him had a plan.
He took off the head, put in on some new concrete road stood on it and had his friend drive slowly in his pickup.
He said he actually got the head to seal up again and got more power. As we all know power is addictive and he did it several more times until the piston had no clearance and the engine wouldn't turn anymore.
Old Mar 16, 2004 | 12:21 PM
[ iLL ] iNt3GrA's Avatar
lol great story
ProjectBB6
Mar 13, 2008 09:24 AM
Ivan_JDM_hatch
12
Jul 13, 2007 06:44 PM
Civichatch27
10
Sep 22, 2004 05:58 PM
1990hondaHF
Apr 8, 2004 11:13 PM
tegasaurus
Dec 23, 2003 02:54 PM
