Radiator problem
Old Mar 16, 2004 | 07:25 PM
lastpunkinline's Avatar
Default Radiator problem
I was just driving like normal and all of a sudden smoke started coming out of my hood and i was like wtf? I pulled into a parking lot popped the hood and my radiator had a little pinhole leak and the water kept dripping on top of some of the metal in my engine. Does anyone know how this could have happened out of the blue? Or how to fix it?Thanx
Old Mar 16, 2004 | 08:56 PM
94gsr4dr's Avatar
Default Re: Radiator problem (lastpunkinline)
rock?
Old Mar 16, 2004 | 09:17 PM
zilverz's Avatar
uhhh it cracked ? radiators go bad ... OEM radiators have a plastic top
Old Mar 18, 2004 | 08:23 PM
Default Re: Radiator problem (zilverz)
Could it be because i redline it when i race? I go all the way to 8?
Old Mar 18, 2004 | 10:33 PM
SonicBlueTeg's Avatar
how many miles u got on that radiator.. if u didnt screw with any of the cooling things they normally blow around 90k+...
my car's top tank blew at 80k-ish... stuipd mugen 1.5 rad cap... never thought that if u dont swap out the thermostat and fan switch when u install the high pressure caps it will cause ur radiator to blow faster... it took out my bf's civic radiator too... guess it took two cars and two radiators to realize this... too late now huh ...
Old Mar 18, 2004 | 10:37 PM
Swift_asian's Avatar
Default Re: Radiator problem (SonicBlueTeg)
mine died around 63k... cost me about 120 for a replacement, made in Taiwai lol
Old Mar 18, 2004 | 11:02 PM
WhoisDan's Avatar
My radiator also died around 60k miles. Stock radiators suck *** because they have plastic pieces. It happens out of the blue sometimes. I was driving one day and I smelled coolant. Radiator.com sells them for 100 bucks.
Old Mar 18, 2004 | 11:15 PM
zilverz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lastpunkinline &raquo;</TD></TR><TR><TD CLASS="quote">Could it be because i redline it when i race? I go all the way to 8?</TD></TR></TABLE>
Its all has to do with Prolonged heat ... other things that people have mentioned like the pressure inside all can effect it ... but in stock form .. Prolonged heat.
As for 8k shifts .. they dont really matter.. what matters is how hot your engine is getting. the water soaks up the heat and keeps it cool ... soo youll want to look at your temp gauge.. If you want to keep the engine/radiator running cooler than stock form ... by some FAL radiator fans .. they are awesome
Old Mar 21, 2004 | 05:49 PM
Yea my Teg has 97k miles, so it's understandable that its breaking down now?
Old Mar 21, 2004 | 05:52 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
dang I feel lucky, my stock radiator sprung a leak last week at 160K miles. I just replaced it with one of those $120 replacements, everything fit in and hooked up perfectly, so hopefully that's a good sign that it will last awhile.
Old Mar 21, 2004 | 06:20 PM
m R g S r's Avatar
Default Re: Radiator problem (PatrickGSR94)
Mine broke right after I put the turbo on my car, so I figured they were related but later found out they weren't. I got pissed off so I bent the stock radiator in half.
Old Mar 21, 2004 | 06:22 PM
Who'd you buy your radiator from?
Old Mar 21, 2004 | 06:27 PM
Community Builder
http://www.radiator.com, I got the CSF brand radiator.
Old Mar 22, 2004 | 08:23 PM
JayDM GSR 34's Avatar
I had a similiar problem w/ mine and my car only had around 54k mi at the time. I had to get my radiator rebuilt...it must be the cheap plastic parts used on the OEM one.
FOMULA91
May 7, 2012 09:22 PM
inaety
Aug 4, 2011 04:15 PM
user 931176363637
Dec 20, 2006 05:40 PM
TC21
May 9, 2006 11:19 AM
EGh22aEG
Jan 9, 2002 06:37 PM
