is 13.5s possible with this setup
Old Mar 15, 2004 | 07:17 PM
luvinmyGSR's Avatar
Default is 13.5s possible with this setup
ok well i hav a 97 gsr...with these mods i was jw if it was possible to hit a 13.5....ok greddy evo 2, high flow cat, and comptech TIG header with comptech ice box...skunk 2 stg 1 cams with springs and reatainers...skunk 2 cam gears...skunk 2 IM...and then get my car tuned...also id b using slicks....and if i couldnt hit this with these mods whut else could i do ....all motor wise...thanx
Old Mar 15, 2004 | 07:27 PM
genetsang's Avatar
Default Re: is 13.5s possible with this setup (luvinmyGSR)
with all that done... youll probably hit some consistant low-mid 14's. Getting into the 13 sec land... youll need some head work and/or higher compression. And runnng slicks with LSD wouldnt hurt either
Train's Avatar
sounds like a mid-low 14 sec car to me
Davanca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luvinmyGSR &raquo;</TD></TR><TR><TD CLASS="quote">ok well i hav a 97 gsr...with these mods i was jw if it was possible to hit a 13.5....ok greddy evo 2, high flow cat, and comptech TIG header with comptech ice box...skunk 2 stg 1 cams with springs and reatainers...skunk 2 cam gears...skunk 2 IM...and then get my car tuned...also id b using slicks....and if i couldnt hit this with these mods whut else could i do ....all motor wise...thanx </TD></TR></TABLE>
i don't think you will hit 13.5 with this setup.maybe between 13.9-14.4.
As far as mods to add, i would go for a type-r lsd or quaife. type-r throttle body, and type-r pistons.
Old Mar 15, 2004 | 07:28 PM
Train's Avatar
Default Re: is 13.5s possible with this setup (genetsang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by genetsang &raquo;</TD></TR><TR><TD CLASS="quote">with all that done... youll probably hit some consistant low-mid 14's. Getting into the 13 sec land... youll need some head work and/or higher compression. And runnng slicks with LSD wouldnt hurt either </TD></TR></TABLE>
damn, beat me to it
Old Mar 15, 2004 | 07:34 PM
91integraLSVTEC's Avatar
Default Re: is 13.5s possible with this setup (Train)
some slicks, gutted interior, some race gas and good driving should defintaly get you there!! i cant even get into 13's with my set up =o( i suck at driving tho
Old Mar 15, 2004 | 07:36 PM
Kendall's Avatar
JDM ITR tranny and about 200 lbs of weight reduction should put you where you want to be.
Old Mar 15, 2004 | 07:37 PM
genetsang's Avatar
shoulda typed faster haha j/p...
Contrary to beliefs... getting into the almighty 13 sec land isnt easy... w/o the dough you car aint gonna flow...
since you got some decent head work. try beefing up the bottom end.
Old Mar 15, 2004 | 07:56 PM
B00ST2nR's Avatar
A JDM ITR tranny will help you out a good amount.
Old Mar 15, 2004 | 09:14 PM
EMO-anthony's Avatar
Default Re: is 13.5s possible with this setup (Skunk2nR)
Get a EMS, ITR pistons, and get it tuned! that right there would get you to the mid 13s!
Old Mar 15, 2004 | 09:18 PM
Kendall's Avatar
I maintain that you should go with a JDM ITR tranny, however I think you should also use a lighter flywheel to help it out even more.
Old Mar 15, 2004 | 10:35 PM
alfaaay's Avatar
Default Re: (Kendall)
I'd have to agree on the Tranny. Some higher comp. pistons as well.
I'm assuming the stuff you listed isn't on your car, so instead it might be better to go with a header that has a 2.5" collector and use 2.5" piping to the back instead of what you have listed.
On a side note, how much whp should someone sitting at to hit 13.5 on some street tires and full interior? sorry to thread jack...
Old Mar 15, 2004 | 10:56 PM
LSTEG96's Avatar
Default Re: (alfaaay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alfaaay &raquo;</TD></TR><TR><TD CLASS="quote">I'd have to agree on the Tranny. Some higher comp. pistons as well.
On a side note, how much whp should someone sitting at to hit 13.5 on some street tires and full interior? sorry to thread jack...</TD></TR></TABLE>
id kinda like to know too... but the weight matters a lot... are u talking just like a normal gsr with no weight mods?
Old Mar 15, 2004 | 11:20 PM
B00ST2nR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alfaaay &raquo;</TD></TR><TR><TD CLASS="quote">On a side note, how much whp should someone sitting at to hit 13.5 on some street tires and full interior? sorry to thread jack...</TD></TR></TABLE>
Usually GS-R's with around 200wHP should get it in 13's.
I just saw the new Honda Tuning mag and there's a white 4-door GS-R with 205wHP doing 13's. It's a daily driver too.
Old Mar 15, 2004 | 11:35 PM
PlastikOwl
Guest
Posts: n/a
Default Re: (Skunk2nR)
race gas is not going to do a lot for you unless you're running some kind of high compression setup.
Old Mar 15, 2004 | 11:40 PM
xdjoynerx's Avatar
just go to the track and see what you run..........
Old Mar 15, 2004 | 11:41 PM
LSTEG96's Avatar
Default Re: (PlastikOwl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PlastikOwl &raquo;</TD></TR><TR><TD CLASS="quote">race gas is not going to do a lot for you unless you're running some kind of high compression setup.</TD></TR></TABLE>
or have some FUCKED up timing
96WhiteOnBlack
Honda S2000
35
Feb 8, 2008 04:34 AM
gilou bilou
16
May 5, 2005 04:25 AM
sickstyle83
Mar 12, 2004 01:57 AM
Rhythm Racer
Jul 15, 2003 09:33 AM
BMac86
May 15, 2003 08:53 PM
