MIL Codes??
Old Mar 16, 2004 | 07:14 PM
Chase Taylor's Avatar
Default MIL Codes??
I have a 91 Integra and need to varify the method of reading the codes from the ECU as the check engine light has comes on.
I have a A/F meter and the guage reads that the A/F is very lean.
The LED on the ECU flashed three long pulses, and then 3 short pulses. Is the first three long pulses a 10, or is that a 30?
Lastly, is the last three short pulses a 3? I would appreciate as much information on this as possible.
I spent four long hours pounding out the upper ball joint assembly just for a seized pin sleeve which needed a BFH to persuade out.
I don't think my 105 female frame was meant to weild a 20 lbs BFH .
Love
Chase Taylor
Old Mar 17, 2004 | 03:49 AM
JimBlake's Avatar
Default Re: MIL Codes?? (Chase Taylor)
I don't have a list of codes for '91, but here goes. Maybe it's the same...
3 long & 3 short = 33, if there's no space between the longs & the shorts. But my list doesn't have anything for 33.
3 long = 30 = auto trans signal A
3 short = 3 = MAP sensor
Old Mar 17, 2004 | 12:43 PM
Default Re: MIL Codes?? (JimBlake)
JimBlake,
Thanks for the input. I checked the ECU for the MIL / CEL code(s) and it was a code 43.
I will have to check the voltage to the O2 sensor, and the fuel pressure regulator for proper PSI levels.
Can someone confirm that the fuel pressure is from 37- 44 PSI with the vacuum hose disconnected for me?
Also, if the voltage from the O2 sensor should be above 0.6 VDC at 4, and 500 RPM's. and below 0.4 VDC when the throttle is quickly released from 4500 RPM's.
Love
Chase Taylor
xxfile
Mar 8, 2009 10:40 PM
CARflyGUY
Dec 15, 2006 03:02 PM
Thundakat85
Apr 17, 2005 01:04 PM
jadugartir
Aug 10, 2004 03:16 PM
bfrank81
11
Oct 26, 2002 02:24 PM
