Non bling-bling pedals with a bit of extension?
This is a pretty specific request, but here goes:
I have an Acura Integra GSR and i have two problems with the pedals on the car(actually the problem is that i'm 5' 4" with small feet)
1. In order to find a comfortable distance for my clutch leg, I have to move the seat back to a distance where I don't have quite enough leverage for the gas pedal. I can still drive, i just can't floor it.
2. The spacing between the brake and gas pedal currently makes toe-heel shifting impossible. I can literally put my foot in the space between the two pedals.
So, is it possible to find a pedal extender that maybe adds an inch to the gas pedal and also has a bit of extension for toe-heel shifting?
I'm trying to find something that doesn't look like it was pried off of a spaceship from a 50's sci-fi show(i.e shiny aluminum, drilled holes, sparkles etc..)
The only other thing I've found are these odd frankenstein looking assemblies for people who are a bit more vertically challenged than i.
Just something nice and plain, black rubber. A inch or two with some extension for toe-heel shifting..
thanks for your time.
-J
-J
Re: Non bling-bling pedals with a bit of extension? (robotsquirrel)
You could always just find the flattest pedal you can find, then put black skateboard grip tape on them (im serious about this). Or just paint them black.
Re: Non bling-bling pedals with a bit of extension? (Xymox007)
Mugen pedal is nice~~ but $$$ Razo carbon filber one is nice.my friend has one on integra..grip good after walking rain day...
Re: (irgaszm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irgaszm »</TD></TR><TR><TD CLASS="quote">why are yall making a big to do outta the foot pedals ???</TD></TR></TABLE>
why can't you click the back button?
Re: (Xymox007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xymox007 »</TD></TR><TR><TD CLASS="quote">
why can't you click the back button? </TD></TR></TABLE>
Re: Non bling-bling pedals with a bit of extension? (ThE bEe GuY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThE bEe GuY »</TD></TR><TR><TD CLASS="quote">You could always just find the flattest pedal you can find, then put black skateboard grip tape on them (im serious about this). Or just paint them black.</TD></TR></TABLE>
thats what ii'm going to do with my stock ones.
my peddles have my reubber or anyting on them. so i'mma get some griptape and stick it on.
edit: most place sell mugen peddles for liek 170, 190 etc but Super Autobac sells them for 80 bucks if u dont mind spending 80 on peddles
Re: Non bling-bling pedals with a bit of extension? (Dc2 Powered)
i used cheapo levo i think is the brand as my pedals. i just didnt use the clips, removed the rubber off the pedal, drilled holes, and used screws and thread lock to bolt it on.
if u wanna go cheap and have sumthing not flashy, get a piece of plywood. 4 bucks of it can make u 20 + pedals
Re: Non bling-bling pedals with a bit of extension? (tekstyle)
i have the honda access ctr pedals and they are pretty grippy...plus they are stock dimensions and perfect fit since they are oem parts....i know they arent bigger than stock but they might help you....if you want some bigger ones that are good quality, you might want to check into the razo ones....they are a little bit bigger and are pretty reasonable...i think you can pick up a set for less than $60.00 or so....good luck
