vafc need help
Old Sep 18, 2004 | 10:57 PM
fro's Avatar
fro
Default vafc need help
im trying to wire up my vafc and im reading the instruction book and then checking it with the chilton just to be on the safe side so i dont **** any thing up, but all the wires are different. for ex. the installition will say green goes to vtec soleniod and i look in the chilton and it says the red one is the vtec.
Old Sep 18, 2004 | 11:04 PM
yeegsr's Avatar
Default Re: vafc need help (fro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fro &raquo;</TD></TR><TR><TD CLASS="quote">im trying to wire up my vafc and im reading the instruction book and then checking it with the chilton just to be on the safe side so i dont **** any thing up, but all the wires are different. for ex. the installition will say green goes to vtec soleniod and i look in the chilton and it says the red one is the vtec.</TD></TR></TABLE>
that why you dont use CHILTON...that book is sux....get ur self a factory integra one...use or brand new...but can you afford it?
Old Sep 19, 2004 | 01:12 AM
davejj40's Avatar
Default Re: vafc need help (yeegsr)
go to bseries.net they have a vafc install guide, it lists out the wire colors i believe, and remember to hook up that vtm wire....also go to the apex site they have info and updates for the vafc too
Old Sep 19, 2004 | 05:20 AM
asubennett's Avatar
Default Re: vafc need help (davejj40)
Use the wiring diagrams that came with the VTEC controller. It should show pin outs for every type of ECU/wiring harness applicable.
Old Sep 19, 2004 | 07:10 AM
zman's Avatar
Default Re: vafc need help (asubennett)
right...so you the green wire from the vafc harness goes with the red wire from your cars harness....its pretty simple install.....took me about 30 minutes. Just use the ecu pinout in the install book from the vafc. Which car is it going in? I did mine on a 95 civic ex. I can tell you exactly which wires went where if you are doing the same car.
Old Sep 19, 2004 | 10:20 AM
davejj40's Avatar
you know wat, just use the wiring diagram and count the pins
Old Sep 19, 2004 | 10:31 AM
TurboTeG4's Avatar
Default Re: (davejj40)
The vafc map wire was giving me code 3 and it was hookedup correct, beware
Old Sep 19, 2004 | 07:45 PM
fro's Avatar
fro
i went to bseries.net and there vafc installation is on a 96 on up and my car is a 95 does that matter.
Old Sep 19, 2004 | 08:39 PM
boosted k20's Avatar
jus go to the http://www.apexi-usa.com and they have the wiring diagrams for u
Mr HYDE
Jun 7, 2004 09:21 AM
Shakes
Feb 26, 2004 01:39 PM
wgs0023
Feb 26, 2004 03:49 AM
Akkord29
Sep 13, 2003 08:29 PM
hatchback19
May 20, 2003 04:50 PM
