ABS removal????
Old Sep 20, 2004 | 02:59 PM
AK94GSR's Avatar
Default ABS removal????
to take the abs unit outta my car what parts do i need to order???
and if anyone has any feedback on this it will probably help out
thanks
Old Sep 20, 2004 | 03:12 PM
Kendall's Avatar
You'll need from Integra RS the front hard lines and proportion valve, everything else should be compatible.
But why get rid of ABS?
Old Sep 20, 2004 | 03:15 PM
rastropovitch
Guest
Posts: n/a
Default Re: (Kendall)
to be one of the in crowd
Old Sep 20, 2004 | 03:18 PM
AK94GSR's Avatar
Default Re: (MSchu)
just because i have taken everything else out(ps,ac)
just gettin rid of the things i dont need and care for
so all i need is RS front brake lines or the hard lines???
and i knew about the proportion valve
anyone else have any input
Old Sep 20, 2004 | 03:26 PM
rastropovitch
Guest
Posts: n/a
Default Re: (AK94GSR)
hard lines and the proportioning valve... do the research and you need everything on teh RS that you don;t have on your abs car... sometimes you may need teh rear hard lines to
Old Sep 20, 2004 | 03:28 PM
AK94GSR's Avatar
Default Re: (MSchu)
i'll look into it more
search ddint help me much, unless someone has a link
Old Sep 20, 2004 | 07:27 PM
HONDA_TYPE_R's Avatar
If your ready for diminished braking distances, then go for it. Go to http://www.g2ic.com. They have an article about removing ABS. You may also find a thread about me wanting to run a J's racing intake and removing the ABS so I could....
Old Sep 20, 2004 | 11:16 PM
migs's Avatar
Default Re: (HONDA_TYPE_R)
If you want all the lines to match up perfectly, you need:
1) All 4 front brake lines
2) Integra RS MC
3) Integra RS BB
4) Integra RS prop valve stamped "4040"
Good luck and it looks a whole lot cleaner.
Old Sep 21, 2004 | 12:49 AM
cloproductions's Avatar
Default Re: (migs)
good info, thanks i needed to know too
Old Sep 21, 2004 | 06:57 AM
Big Teggie's Avatar
Default Re: ABS removal???? (AK94GSR)
Here is a thread with the part numbers I used to remove my ABS in my 01 GSR.
http://m24x.zeroforum.com/zerothread?id=995
Old Sep 21, 2004 | 09:07 PM
b-power's Avatar
Default Re: ABS removal???? (Big Teggie)
bump
IT'S ME DAVID
Sep 10, 2009 08:27 PM
GSR-TRBO-DA
Sep 16, 2007 06:32 PM
Vcastro
Oct 13, 2006 08:46 AM
JimmyAtlantis
Dec 8, 2005 10:38 AM
rochnyteg
Jul 15, 2004 12:49 AM
