OBDII CODE 22
Old Sep 18, 2004 | 08:40 PM
97dc2's Avatar
Default OBDII CODE 22
well i installed a vafc II like other people had suggested but the code 22 still shows up and i also changed the plug that the green plug plugs into and its still showing up. The oil is fine, and when the check engine light is on sometimes it lets me redline normally and most of the it kicks back at 6200.
What else can i do?
Old Sep 18, 2004 | 10:08 PM
boosted k20's Avatar
Default Re: OBDII CODE 22 (97dc2)
wait, were u getting the cel code 22 before u installed the VAFC or after the VAFC install. if ur getting it after u installed the VAFC then u probably didnt hook it up right. u probably got the VTEC 'in' and 'out' wires on the VAFC switched.
but if u had the CEL code 22 b4 u installed the VAFC, u might have low oil (but u said thats not the case) or a burnt out vtec solenoid. there might be more causes for that code too
Old Sep 19, 2004 | 01:15 AM
davejj40's Avatar
yea check the vtec solenoid, clean the filter or replace that thing...if a cel 22 popped out after the vafc was installed it would be the vtm wire...
Old Sep 19, 2004 | 05:41 AM
tegon-gsr's Avatar
Its your VTM wire. go to the ecu look for the vtm wire check to see if it is connected if not connect it but make it a single loop dont have it running with full loop you will have to snip the factory vtm wire.
Old Sep 19, 2004 | 04:25 PM
97dc2's Avatar
Default Re: OBDII CODE 22 (boosted k20)
i started getting the code 22 before i installed the vafc, and i also changed the gasket so i know that the filter is clean
Old Sep 19, 2004 | 06:32 PM
vtec solenoid probably burnt out
Old Sep 19, 2004 | 08:54 PM
97dc2's Avatar
if the vtec solenoid was burnt out would vtec still engage? Because my vtec still engages
Modified by 97dc2 at 10:05 PM 9/19/2004
pbizzlegsr
Mar 8, 2004 04:33 PM
topsekret
Dec 22, 2002 05:49 PM
.Beaver
28
Nov 19, 2002 04:31 PM
