> how often does one need to clean the vtec solenoid?
Old 09-18-2004, 10:52 PM
Xymox007's Avatar
Default > how often does one need to clean the vtec solenoid?
i was wondering if there was a proper procedure and time/mileage interval for cleaning the vtec solenoid on B18C1s.
that is all.
thanks.
Old 09-19-2004, 04:13 AM
Xsi
Xsi's Avatar
Mine has been 14 years and counting. Personally I'd say if it ain't broke . . . .
Old 09-19-2004, 06:09 AM
slooogsr's Avatar
i would like to know the answer as well.....
ive been noitcing a few times that when im driving into vtec range it does not kick in for some reason.......
anyone have any directions on cleaning it?
Old 09-19-2004, 06:13 AM
mr.beeks's Avatar
Default Re: (slooogsr)
its all in your hands how often you change your oil
and how often you check the vtec solenoid filter
if there is build up just clean it up..
Old 09-19-2004, 06:18 AM
iixerOii's Avatar
Default Re: (mr.beeks)
Hmm underneath my hood the guy the owned the car before sprayed clear coat all over everything, like the distributor cap, and vtec solenoid. It seems when he sprayed it though he didn't clean it off first. So theres nice layer of dust/oil or something trapped underneath the clear coat. Anyone know a way I can remove the clear coat safely off the vtec solenoid?
saleensolution's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks &raquo;</TD></TR><TR><TD CLASS="quote">its all in your hands how often you change your oil
if there is build up just clean it up..</TD></TR></TABLE>
keep that oil cahnged and filter changed and you should be ok there should be no reason you need to clean it out. its not in the service manual saying to change or clean after so many miles
Old 09-19-2004, 07:46 AM
Xymox007's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slooogsr &raquo;</TD></TR><TR><TD CLASS="quote">
first check your oil level and pressure.
Old 09-19-2004, 07:57 AM
slooogsr's Avatar
Default Re: (Xymox007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xymox007 &raquo;</TD></TR><TR><TD CLASS="quote">
first check your oil level and pressure.</TD></TR></TABLE>
i always keep tabs on that, oil pressure is great as well...... just around 136k miles on it.
volcomej1
06-25-2011 12:07 PM
em1gangsta
17
03-19-2008 09:38 AM
jxj220z28
02-12-2004 11:38 AM
Fraggle
01-12-2004 12:15 PM
KTeller8
12-03-2003 04:40 AM
Quick Reply: > how often does one need to clean the vtec solenoid?
