which fuse for coompression test???
Old Sep 17, 2004 | 11:23 AM
StolenTeg's Avatar
Default which fuse for coompression test???
When testing compression, which fuse do i take out so the injector wont inject fuel??? on gsr it say 15a but i dont see 15a anywhere on my LS. Does LS and GSr have different fuse???
Old Sep 17, 2004 | 12:27 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: which fuse for coompression test??? (StolenTeg)
I don't even bother with the injector one.
Just take out the 15A ECU fuse in the engine bay.
Old Sep 17, 2004 | 12:37 PM
garados's Avatar
Default Re: which fuse for coompression test??? (shamoo)
I'll second that. Go to the fuse box near the battery and take out the ECU fuse (15a) and do the comp. test.
Old Sep 17, 2004 | 01:26 PM
2chron4u's Avatar
Default Re: which fuse for coompression test??? (garados)
werd, ecu fuse it is
Old Sep 17, 2004 | 01:33 PM
vtec69's Avatar
dont even worry about a fuse just unclip the injector clips and your good to go
Old Sep 17, 2004 | 01:44 PM
boosted k20's Avatar
Default Re: which fuse for coompression test??? (vtec69)
much easier to take out the fuse. dont even bother wasting an extra 5 mins to pull out the injector clips!
Old Sep 20, 2004 | 11:25 AM
2chron4u's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec69 &raquo;</TD></TR><TR><TD CLASS="quote">dont even worry about a fuse just unclip the injector clips and your good to go</TD></TR></TABLE>
did you realize it's an underhood fuse? nothing could be easier,
Old Sep 20, 2004 | 11:30 AM
s2kkid's Avatar
LOL i didnt disable the feul when i did mine... Does that have a bearing on the test or just general safety?
I thought it was a safety issue but I didnt feel like looking for the fuse, i did it without and nothing bad happend i suppose
Old Sep 20, 2004 | 12:34 PM
JimBlake's Avatar
Default Re: (vtecluder97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecluder97 &raquo;</TD></TR><TR><TD CLASS="quote">Does that have a bearing on the test or just general safety?</TD></TR></TABLE>Sorta both. If you haven't disabled spark, then maybe one of your plug wires might spark against a ground. If there's fuel spurting out of the plug holes... ??
The fuel will wet the cylinder walls & influence the rings' seal. You'll build up more fuel as you measure each cylinder, so it'll be different as you go.
Old Sep 21, 2004 | 01:39 PM
2chron4u's Avatar
Default Re: (JimBlake)
if you don't disable the fuel pump you'll get lower readings, not to mention gas in your oil and comustion cylinders.
the fuel will wash away the oil that help the rings seal, and you'll get lower readings because of it.
Hanmin
May 16, 2008 02:17 AM
si0385.
20
Apr 17, 2006 08:12 AM
BLK99VTECR
Aug 5, 2004 07:18 PM
Cryptopsy
Jan 18, 2002 10:24 PM
