driver's pwr window doesn't work. HELP!
i've got a 90 4 dr teg. just earlier, my drivers pwr window stopped working. all the other windows work and the fuses are fine. could it be that the motor to roll the window up or down is toast ?
someone help!
someone help!
you could check power and ground at the switch if you have a multi-meter(checks voltage/amps/resistance) check how much voltage you got at the connector for the switch and check the ground for high resistance for a start
the switch could be broke, or just give it a good couple of bangs, i did it in my 93 and it worked fine after i hit the door around the switch a couple times lol sounds weird but worked for me
ok. i will check for voltage, ground. i read on a G2 website that the contacts might be dirty so i'm gonna check that too. any other suggestions ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jinteg730 »</TD></TR><TR><TD CLASS="quote">the switch could be broke, or just give it a good couple of bangs, i did it in my 93 and it worked fine after i hit the door around the switch a couple times lol sounds weird but worked for me
AH yes the old "give it a technical tap" method
Yeah I would check the voltage to see if you are getting power to the motor first.
well for some odd reason, its working again! i guess it just froze for a couple days but i pray nothing happens anymore. thanks again!
wmflyfisher
Feb 15, 2007 05:47 PM
