potential problems with the integra?
Old Nov 28, 2004 | 11:42 AM
Rs xtreme 415's Avatar
Default potential problems with the integra?
just got my new used integra 94 rs. 105k. the damn owner seemed like he didnt take care of it. the battery is almost shot. the battery light and the oil light is on. i changed the oil( high mileage one 10-30, 5 quarts) and the damn light is on... i need some light on this.. there was a oil leak and i sense that the damn pan must be changed soon.. maybe a simple motor swap will change all these problems
Old Nov 28, 2004 | 12:18 PM
Default Re: potential problems with the integra? (Rs xtreme 415)
help?
Old Nov 28, 2004 | 12:27 PM
hotsuma23's Avatar
Well what are you asking for help with? Where is it leaking oil? Head gasket? Oil pan? Is it throwing any codes? I say you do a compression test and post the results. You could swap in another b18b1 for $500 or so. They are not very expensive.
Old Nov 28, 2004 | 01:24 PM
Stripped Honda's Avatar
99-0104
Default Re: potential problems with the integra? (hotsuma23)
why 5 qts of oil? it takes 4qts tops .... now on the oil light i would first change the oil pressure switch , then drop the oil pan and clean the pickup screen as it may be clogged with particals ... if that doesent solve the problem then you need to hook up a oil pressure gauge and see how much pressure you have ... if it is really low then a oil pump would be in order .... it is possible for it to be the wiring but do the pressure test first ...
the battery light usually means that you need a alternator
good luck ...
Old Nov 28, 2004 | 01:26 PM
hotsuma23's Avatar
Default Re: potential problems with the integra? (Stripped Honda)
Yea I didnt notice that. 5 quarts is too much oil dont run it like that. Drain out about a quart and then check your oil level.
Old Nov 28, 2004 | 05:06 PM
well now. 5 quarts and the level is evened out. but the damn oil light and battery light is on. i changed the battery. and oil. i think i may get a new oil pan..
Old Nov 28, 2004 | 05:13 PM
Kowalski's Avatar
How'd you fit 5 quarts of oil if it's supposed to only hold 4?
Old Nov 28, 2004 | 05:17 PM
DannyBoy_Db8's Avatar
Default Re: potential problems with the integra? (Kowalski)
oil light is on and your still drivin it around? thats not good
Old Nov 28, 2004 | 05:23 PM
stareatsun's Avatar
you realize that ou can put like 8 or 9 qts of oil in the motor and it wont flow out. Just dont run it. 4 qts. oil light can lead to a pressure problem.
Old Nov 28, 2004 | 05:31 PM
Default Re: potential problems with the integra? (DannyBoy_Db8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DannyBoy_Db8 &raquo;</TD></TR><TR><TD CLASS="quote">oil light is on and your still drivin it around? thats not good</TD></TR></TABLE>
i bought it yesterday.. i ran it home. bought some oil changed it this mornining..
Old Nov 28, 2004 | 05:33 PM
Default Re: (stareatsun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stareatsun &raquo;</TD></TR><TR><TD CLASS="quote">you realize that ou can put like 8 or 9 qts of oil in the motor and it wont flow out. Just dont run it. 4 qts. oil light can lead to a pressure problem.</TD></TR></TABLE>
ok so should i let out half a quart.
Old Nov 28, 2004 | 06:03 PM
yodas-gsr's Avatar
Default Re: (Rs xtreme 415)
check the oil dip, and see how much you have in there...
Old Nov 29, 2004 | 07:51 AM
Default Re: (yodas-gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yodas-gsr &raquo;</TD></TR><TR><TD CLASS="quote">check the oil dip, and see how much you have in there...</TD></TR></TABLE>
check.
Old Nov 29, 2004 | 09:01 AM
damn battery is giving me problems. i installed a new battery. ran good yesterday.. now on to this morning. the damn thing doesnt even crank. just a couple of click noises. i try to jump it with the damn jumper. didnt work. disconnected the battery then it worked. shut off then had the same problem. so i decided to gas it while i try starting then worked... i think my parents bought me a piece of junk. is something wrong with the starter. or should i get a new starter and a set of plugs?
Old Nov 29, 2004 | 09:18 AM
Train's Avatar
check your ground connections. check the ground to the starter and the ground between the valve cover and radiator support. do an oil pressure test and post the results. a compression test would be a good thing to do also. post those results as well.
Old Nov 29, 2004 | 05:11 PM
Default Re: (Train)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Train &raquo;</TD></TR><TR><TD CLASS="quote">check your ground connections. check the ground to the starter and the ground between the valve cover and radiator support. do an oil pressure test and post the results. a compression test would be a good thing to do also. post those results as well.</TD></TR></TABLE>
hm. i dont know how to do all that. but the car before sold was running good. passed smog and everything, but when i bought it right away it seemed like all these problems started to happen. hm?
Old Nov 29, 2004 | 07:56 PM
kimo98GSR's Avatar
Sounds like your system is having a grounding problem. You will want to check all ground cables. The Battery light is caused when your alternator quits charging the battery, you might need to look into getting a new alternator not a new starter. You might want to look into getting a new set of ground wires. I know HKS makes a circle earth system that will run you about $100. That would be a good starting point.
Old Nov 30, 2004 | 07:12 AM
Default Re: (kimo98GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kimo98GSR &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like your system is having a grounding problem. You will want to check all ground cables. The Battery light is caused when your alternator quits charging the battery, you might need to look into getting a new alternator not a new starter. You might want to look into getting a new set of ground wires. I know HKS makes a circle earth system that will run you about $100. That would be a good starting point.</TD></TR></TABLE>
so new alternator it is and a set of ground wires?
Old Nov 30, 2004 | 06:47 PM
Old Nov 30, 2004 | 08:53 PM
kimo98GSR's Avatar
If all of your OEM ground wires are connected and tight, and you are still having the starting problems, you might want to look into the circle earth grounding kit. IF you have a loose ground wire, then you would want to just fix the wire and see if that fixes the prob.
Another thing that you might be having problems with is the battery terminal. If they aren't connecting tightly to the terminal, then you might want to look at replacing those also.
Greg50Lt
Honda Civic (2006 - 2015)
Nov 7, 2009 03:08 AM
Steven.
Jun 10, 2008 12:32 PM
FmXRider991
Apr 16, 2005 12:41 PM
FmXRider991
Apr 11, 2005 02:34 PM
Mr. Samurai
10
Feb 28, 2005 05:59 PM
