LS, GS compression
Old Nov 28, 2004 | 10:23 AM
hugo7's Avatar
Default LS, GS compression
just wondering what is the stock compression on these cars? are they different or the same which one is better
Old Nov 28, 2004 | 10:29 AM
dFreezy's Avatar
Default Re: LS, GS compression (hugo7)
they're the same, 9.2:1
Old Nov 28, 2004 | 10:48 AM
hugo7's Avatar
Default Re: LS, GS compression (dFreezy)
well here is the thing i have 94-01 b18b block with internals from a gs and a 93 head and the car feels like it should pull a lot harder than what it does so im thinking maybe ls and gs have different compression i have a 95 hatchback
Old Nov 28, 2004 | 01:30 PM
skunk2eg's Avatar
94-01 LS an GS is the same motor....B18B,
the 93 head is off a B18A, shouldnt make a difference
Old Nov 28, 2004 | 01:34 PM
Elemental's Avatar
the 93 head shouldnt make a difference really.
the b18b and b18a engines are nearly identical.
Old Nov 29, 2004 | 05:29 AM
Integrt's Avatar
Default Re: (Elemental)
Gs just means leather on the 3rd Gens
Old Nov 29, 2004 | 06:14 AM
JustinG60's Avatar
Default Re: LS, GS compression (skunk2eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2eg &raquo;</TD></TR><TR><TD CLASS="quote">94-01 LS an GS is the same motor....B18B,
the 93 head is off a B18A, shouldnt make a difference</TD></TR></TABLE>
well i should start with the 93 is a B18B and not a B18A which is found in a 1990 and 1991 teg, but if it were a B18A head that would be the reason for your loss in power since they are a slight bit difference (130hp on a B18A and 142hp on a B18B and the difference of the 2 is in the heads) , the cams are for one does not have as big of lift on them as the B18B cams... and it is also OBD0 rather than OBD1 so you would have had to convert the dist. to the OBD1 plugs. but this is where i am not sure, i do believe though you would have just been able to use a B18B dist. though and not have to convert the plugs obviously...
since you recently pulled your head and looking for more of a "pull" should look into a B16 trans
MidwestAutoWorks
May 3, 2007 08:22 AM
whoa its len 2
Oct 26, 2005 12:47 AM
b16
Jul 3, 2003 06:33 AM
The Rob
Jun 18, 2002 11:30 AM
Cyrius
Oct 26, 2001 08:22 PM
