antenna problem
Old Nov 30, 2004 | 06:50 PM
B20poweredDA's Avatar
Default antenna problem
today I installed a radio and now i cant find the damn connection for the wire. not the wire that connects to the radio but the other end of the wire.
Old Nov 30, 2004 | 07:33 PM
.doeboyfresh.'s Avatar
From: Boswanna,street radio,riddin in da regal. PA.LLday
Default Re: antenna problem (B20poweredDA)
dude thats sounds like a problem...im not help on this one though
Old Dec 1, 2004 | 10:03 AM
yee SERIOUS's Avatar
are you referring to the wire that signals the antenna to go up?
i have the same problem. my antenna doesn't go up cause my deck doesn't have a wire to connect with the harness. my reasoning, who cares, antenna is ugly and i don't listen to radio much anyways. lol.
but i'm wondering if i could wire it up to power and make a switch for it. so i can have it go up whenever i wanted. i'll have to check the wiring for how much voltage it should be recieving.
if this is the same problem you're having, then i can check the helms manual at my work place today and get back to you by tomorrow sometime.
Old Dec 1, 2004 | 10:42 AM
dFreezy's Avatar
Default Re: antenna problem (TeGmAn18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeGmAn18 &raquo;</TD></TR><TR><TD CLASS="quote">dude thats sounds like a problem...im not help on this one though </TD></TR></TABLE>why did you post then? suiting title....
it probably just fell back behind the headunit when you pulled it out. try reaching back there and grab the loose wire, just be careful you don't yank something else out
Old Dec 1, 2004 | 12:20 PM
Mike Mafia's Avatar
Default Re: antenna problem (dFreezy)
Mine actually still went up and down with my new deck but about a month ago it got stuck up and now whenever i turn the radio on the antena motor just sounds like it's grinding and the attena just stays up... help?
Old Dec 1, 2004 | 07:56 PM
boynxtdr's Avatar
Default Re: antenna problem (Mike Mafia)
im having that same problem with my teg too
Old Dec 1, 2004 | 08:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike Mafia &raquo;</TD></TR><TR><TD CLASS="quote">Mine actually still went up and down with my new deck but about a month ago it got stuck up and now whenever i turn the radio on the antena motor just sounds like it's grinding and the attena just stays up... help?</TD></TR></TABLE>
sounds like you need an antenna. go down to the dealership and have it replaced. or maybe you'll want to do the s2k antenna conversion? but you're problem is the motor slipped off the rails i think. i see cars like that at honda all the time. manager tells us to just push down the antenna so it can go in the car wash. lol
Old Dec 2, 2004 | 07:15 PM
Mike Mafia's Avatar
Default Re: antenna problem (LiTtOGPiMp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LiTtOGPiMp &raquo;</TD></TR><TR><TD CLASS="quote">
manager tells us to just push down the antenna so it can go in the car wash. lol</TD></TR></TABLE>
That's hella funny haha!!! How much would the process cost "i'm being a huge cheapscate right now" cause my job sucks. -Thanks
Old Dec 2, 2004 | 09:07 PM
B18C5er's Avatar
Do what I did. I installed a Pioneer deck in my car and there was no power antenna lead coming out of the deck, So i used the Amp switch lead. Does the exact same thing as a power antenna lead would do.
Old Dec 2, 2004 | 09:57 PM
That's hella funny haha!!! How much would the process cost "i'm being a huge cheapscate right now" cause my job sucks. -Thanks</TD></TR></TABLE>
price varies from location. call ur local acura dealership for a price quote. i'm sure you can find a cheaper deal online at one of those acura oem parts sites. the helms manual shows and tells how to replace it. i saw it yesterday.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5er &raquo;</TD></TR><TR><TD CLASS="quote">Do what I did. I installed a Pioneer deck in my car and there was no power antenna lead coming out of the deck, So i used the Amp switch lead. Does the exact same thing as a power antenna lead would do.</TD></TR></TABLE>
i think u can just wire up that antenna lead wire to the power and it should work the same. the antenna lead wire is yellow/green on the stock harness. i don't know what the color is for the aftermarket plug.
fergs96integra
Audio / Security / Video
23
May 22, 2006 09:17 AM
TurboEM1
Dec 7, 2005 09:27 AM
ef-hatchcrap
12
Aug 4, 2005 11:37 AM
Slvr_CRX
Feb 23, 2005 07:27 AM
OuNcE
Sep 21, 2003 04:14 PM
