Radio Code................
Old Nov 30, 2004 | 09:02 PM
bLuEciVicGuY's Avatar
Default Radio Code................
Does anyone have the code for the stock cd deck for the 98 integra?
Old Nov 30, 2004 | 09:31 PM
virusiidx's Avatar
i think u can pull out the radio and check on the back, there should be a label with the code written on it.
Old Nov 30, 2004 | 09:34 PM
Default Re: (virusiidx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by virusiidx &raquo;</TD></TR><TR><TD CLASS="quote">i think u can pull out the radio and check on the back, there should be a label with the code written on it.</TD></TR></TABLE>
Did that already.anyone else
Old Nov 30, 2004 | 09:37 PM
virusiidx's Avatar
I'm not sure on this one, but i think u can also go down to acura and they can find out using your vin.
Old Nov 30, 2004 | 09:50 PM
Mart_It's Avatar
Default Re: Radio Code................ (bLuEciVicGuY)
The code will <U>not </U> be found on the back unless it was hand written. Honda does not write any codes on the back of their radio's. If you want, Email me the radio's serial number on the back of the deck and I will get you the code tomorrow at work!
Old Dec 1, 2004 | 09:57 AM
yee SERIOUS's Avatar
check your fuse box cover. ther might be a sticker on it with the code. i'm referring to the fuse box under your hood.
if it's not there, open your glove box, and on the sides, the sticker might be there.
i know cause i work at honda
Old Dec 2, 2004 | 03:13 AM
Gerbilo's Avatar
Default Re: (LiTtOGPiMp)
I have a lil code card w/ my owners manual, if you have yours maybe check there.
Old Dec 2, 2004 | 06:30 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: Radio Code................ (Mart_It)
The easiest way to get it is with the code/serial on the sticker that is on the headunit.
That's the code/serial you Need to give to the dealer to get the activation code for the headunit.
Not sure where that fuse box one came from, it doesn't really have anything to do with the headunit.
Old Dec 2, 2004 | 09:22 AM
Default Re: Radio Code................ (FlatBlackTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackTeg &raquo;</TD></TR><TR><TD CLASS="quote">The easiest way to get it is with the code/serial on the sticker that is on the headunit.
Not sure where that fuse box one came from, it doesn't really have anything to do with the headunit.</TD></TR></TABLE>
you need to give the serial no. on the deck. the dealership will just type that in and the code will appear. like magic
when the dealership does PDI's on new cars. there is a couple radio code sticker given, usually it'll have the radio serial no and the code. there are 2 places to put that sticker. usually they put that sticker on the cover of fuse box(the one under the hood). that's where mine was. i bought my car used and i didn't get the radio code card, but i found it under the hood. the other place they put the sticker is on the side of the glove box.
save yourself 10 bucks by checking to see if it's there. i do it for ppl all the time. remember not all decks need a code.
Old Dec 2, 2004 | 09:26 AM
omiehomie's Avatar
Default Re: (bLuEciVicGuY)
either the back of the deck or go to the dealer one of the two
wmflyfisher
Oct 2, 2008 11:35 AM
ramstrung
Sep 16, 2007 04:45 PM
radioblus
Jul 18, 2007 01:37 PM
Melikanw3rkit
Acura TSX
Mar 9, 2007 07:13 AM
atomx
Aug 8, 2001 02:31 PM
