clutch problem
Old Nov 29, 2004 | 10:49 AM
rough_draft's Avatar
Default clutch problem
whenever i slip the clutch when tkaing off in first gear i hear a loud squeeling. it does it a tiny bit in 2nd gear too, i was told that it's my clutch master cylinder. Is this true? Do i need to replace it or is there any way i can fix it? I'ts a gsr tranny btw, help me out guys. Thanks
Old Nov 29, 2004 | 11:05 AM
IVI's Avatar
IVI
Default Re: clutch problem (rough_draft)
its a bearing i believe not the clutch master cylinder.
Old Nov 29, 2004 | 11:56 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: clutch problem (IVI)
Is it squeaking during actual engagement? Or during the pedal travel?
Do you have an aftermarket disc?
Old Nov 29, 2004 | 05:32 PM
it's not the throwout bearing cuz i just replaced that.. it's when i'm taking off in first gear and i slowly slip the clutch... like actual engagement. It is stock disc and clutch. ty
Old Nov 29, 2004 | 06:18 PM
shamoo's Avatar
Default Re: (rough_draft)
Well, if it was during pedal travel, then it would most likely be the throwout bearing. However, you said you replaced that anyway. You also said it occured during engagement.
Hmm.....usually a squeaking would occur if you weren't using an organic disc and you were using a full/semi metallic material. Did you recently make a "mistake" and accidently glaze the disc over? How long ago did it start doing this?
Old Nov 30, 2004 | 11:00 AM
could it be a clutch master cylinder?
Old Nov 30, 2004 | 12:36 PM
IVI's Avatar
IVI
the clutch master cylinder is just a cylinder that holds the hydraulic fluid. its part of the hydraulic system.
it really doesnt have any moving parts that would make something squeal.
Old Nov 30, 2004 | 12:49 PM
what if its leaking?
Old Nov 30, 2004 | 01:02 PM
IVI's Avatar
IVI
if its leaking you would have a hard time engaging and disengaging. you would see fluid loss in the reservoir.
Old Dec 5, 2004 | 09:01 PM
hm, what about if ur tranny is leaking?
Mr.Death
Transmission & Drivetrain
Mar 9, 2017 09:12 AM
Chris Miller
Mar 28, 2016 10:49 AM
MugenGTR
Jan 29, 2012 02:14 PM
midnitesol
Nov 24, 2010 05:57 PM
Z7
11
Feb 9, 2006 06:53 PM
