ABS problem
Old Nov 29, 2004 | 08:15 PM
jay_96teg's Avatar
Default ABS problem
I need help... I had a custom install done with my stereo. I had a sub and amp custom mounted in my spare tire well by tweeter. since then my abs light has been comming on when I have the stereo cranked up. the head unit even tuns off ocassionally. What the **** is up with my stereo. Help guys. I know you will come through. jay in PA
Old Nov 29, 2004 | 08:19 PM
jay_96teg's Avatar
Default Re: ABS problem (jay_96teg)
I know that the brakes still work, but entering the winter season, I want ABS. The ABS light goes off when i turn the stereo back down.
***Brand new head unit $600 alpine head unit, jbl 1000 watt amp, and Alpine type R sub.
Please help guys
Ocassionally head unit turns off then turns back on??
HELP
Old Nov 30, 2004 | 04:24 AM
JimBlake's Avatar
Read the ABS error code, just like reading an engine ECU code. Jumper the connector but watch the ABS light flashing. Check out the sticky thread at the top here.
The ABS computer is near the right-rear shock tower, & there's a wire from the left-rear wheel sensor that goes along the forward edge of the trunk floor. Something got messed up during the sub & amp install??
Old Nov 30, 2004 | 04:54 AM
jay_96teg's Avatar
Default Re: ABS problem (JimBlake)
what wires do i jumper to get the abs light to throw the code???
I will take my car back to tweeter to have them check the install.
Old Nov 30, 2004 | 09:25 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jay_96teg &raquo;</TD></TR><TR><TD CLASS="quote">what wires do i jumper to get the abs light to throw the code???</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Check out the sticky thread at the top here.</TD></TR></TABLE>Look in the corner between the glovebox & the right kick-panel. Stuffed up in there somewhere is a green rubber holder with 2 blue plastic electrical plugs. One of them has 2 wires, the other has 3. You want the one with 2 wires. Bend a paperclip to jumper between the 2 wires in that connector. Then follow the instructions in the sticky thread at the top of this forum.
Old Dec 6, 2004 | 09:59 PM
jay_96teg's Avatar
thanx for your help jimblake...tuns out tweeter fully tested and i have a dead cell in my battery. system is pulling too much power.
i need a new battery and a capacitor for my system.
Old Dec 6, 2004 | 10:32 PM
Bay_707's Avatar
i was going to ask if it was grounded properly..
Doc_Stu
Apr 11, 2008 05:18 PM
cioli
Jul 29, 2006 11:52 AM
jay_96teg
Audio / Security / Video
Mar 18, 2005 06:20 PM
Dirt
Jun 6, 2002 05:16 AM
Mike B
Apr 17, 2002 09:36 PM
