Quick Question LSvtec?
Old Feb 21, 2006 | 07:47 PM
LSinteg23's Avatar
Default Quick Question LSvtec?
If I go Lsvtec, will I have problems getting the car smogged? And whicht is a better vtec head? SI head or GSR head? Thanks in advance.
Old Feb 21, 2006 | 08:01 PM
TypRice's Avatar
head...SI...
smog...you should be fine!
what ecu will you run?
TypRice's Avatar
what year is the car?
Old Feb 21, 2006 | 08:17 PM
LSinteg23's Avatar
Default Re: (TypRice)
I don't know what ecu to use or what I have, but I have a 95 LS. Thanks for the response.
Old Feb 21, 2006 | 08:43 PM
shorto85's Avatar
No you won't be able to smog it because it will fail the visual
Old Feb 21, 2006 | 08:47 PM
sydegsr's Avatar
Default Re: (shorto85)
si head is better flowing, more comming among the two in lsvtec projects, go with that one
Old Feb 21, 2006 | 08:56 PM
bks84's Avatar
Loved
i would, if i were you... use the ECU from a 94-95 Del Sol its obd1
Old Feb 21, 2006 | 08:59 PM
brian3676's Avatar
Default Re: (sydegsr)
what is the visual and how will this convertion make it fail? thanks brian
Old Feb 21, 2006 | 10:43 PM
watsvtecEK's Avatar
Default Re: (brian3676)
in Cali, they do a visual inspection. they will see the dohc vtec on the valve cover when on the computer it says dohc non-vtec. so unless you go to a really unstricked or stupid smog tech. then you may pass. Another thing you can do is get a aftermarket valve cover that dose not say vtec. or shave the vtec of the oem valve cover.
Old Feb 23, 2006 | 09:42 AM
LSinteg23's Avatar
So in other words...I shouldn't go lsvtec?
Old Feb 23, 2006 | 09:47 AM
SlamminS85's Avatar
Default Re: (LSinteg23)
not if the only purpose is to pass a smog test
you should just hide it, you shoudl use your current valve cover on your new head if it fits... i dont know if it will or not, but that would be the best solution
Old Feb 23, 2006 | 10:33 AM
Spectrum24x's Avatar
Default Re: (SlamminS85)
Between the heads, it depends... if you plan on upgrading your cams, go with b16 head, it flows better, but if not, the GSR head has more aggressive cams..
essentially, stock, there gonna make about the same numbers
Old Feb 23, 2006 | 10:40 AM
AGPDB2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlamminS85 &raquo;</TD></TR><TR><TD CLASS="quote">not if the only purpose is to pass a smog test
you should just hide it, you shoudl use your current valve cover on your new head if it fits... i dont know if it will or not, but that would be the best solution</TD></TR></TABLE>
I'm pretty sure the LS valve cover will not fit a vtec head. Like the kid said before, just do LS/Vtec because yes, it's ridiculous, but get a clean vtec valve cover, and shave it down smooth so they cannot see VTEC on it. You should be able to pass it that way. and dont put the spark plug cover on, just incase That's just what I think. I dont live in Cali, they could care less here in wisconsin.
JDMPR
Oct 15, 2009 06:26 PM
JDMDC2BOY12
May 18, 2008 08:03 AM
Street Inc
Jan 17, 2006 11:22 PM
watsvtecEK
Jan 9, 2006 04:49 PM
