header/manifold
Old Feb 19, 2006 | 02:20 PM
iheartmyej8's Avatar
Default header/manifold
i am builind a ls/vtec, b16 head b18 block. what kind of header/manifold will fit? should i get b16 or b18 header/manifold?
Old Feb 19, 2006 | 04:52 PM
dohcMONSTER's Avatar
Default Re: header/manifold (iheartmyeg)
the only difference is the length of the collecter. All B series headers fit the head fine
Old Feb 19, 2006 | 05:09 PM
Tornadom's Avatar
I would get a header designed to handle the extra flow of VTEC. In my opinion, get the header for a B-16, or B-18C. Toda makes a nice header.
Old Feb 19, 2006 | 05:42 PM
Default Re: header/manifold (Tornadom)
about how much do todas run?
Old Feb 19, 2006 | 05:50 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Lots I'm sure, if you want to Spend money on a header, Get a Hy-tech.
Old Feb 20, 2006 | 05:04 PM
Default Re: header/manifold (FlatBlackTeg)
well i am on a budget right now, cause im buildn the motor, so the cheaper the better
Old Feb 20, 2006 | 05:47 PM
will a 99 si header fit? cause all i can really find are 2 piece for my da and i want 1 piece
Old Feb 20, 2006 | 06:32 PM
CivicSiDriver02's Avatar
You could buy a dc header and do a 2.25 or 2.5 inch collector mod. You might be able to pick up a used one cheap on ebay. Remember however, you get what you pay for.
Old Feb 21, 2006 | 09:43 AM
Tornadom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iheartmyeg &raquo;</TD></TR><TR><TD CLASS="quote">will a 99 si header fit? cause all i can really find are 2 piece for my da and i want 1 piece</TD></TR></TABLE>
Yes it will bolt up to the head. Will it clear your radiator fans and things like that, I am not sure. DC is okay for an inexpensive header, I currently have one on my GS-R. Toda headers are about a grand, so are some of the custom headers. If you are on a budget, DC will do you well.
Old Feb 21, 2006 | 07:06 PM
thanks, so should i buy the dc header for an si or should i buy it for the da?
Old Feb 22, 2006 | 07:32 AM
Tornadom's Avatar
For the SI
Old Feb 22, 2006 | 09:13 AM
nickG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iheartmyeg &raquo;</TD></TR><TR><TD CLASS="quote">thanks, so should i buy the dc header for an si or should i buy it for the da?</TD></TR></TABLE>
all b-series headers are interchangable...you want one w/ a 2.5" collector..and youll probably need some custom exhaust work done to connect it
Old Feb 22, 2006 | 05:08 PM
Default Re: header/manifold (nickG)
thanx
Old Feb 22, 2006 | 05:38 PM
ernald711's Avatar
get a good 4-1 and a AEBS.
93egSLEEPER
Dec 14, 2008 07:31 PM
Ryan6838
Apr 9, 2008 06:11 AM
blk_eg4
Jun 17, 2007 05:19 PM
zerogravitycrx
Dec 5, 2006 05:14 AM
itr1244
Welding / Fabrication
Sep 4, 2006 09:04 PM
