Wont Start
Old Feb 19, 2006 | 11:43 AM
onepoint-gsr's Avatar
Default Wont Start
I was driving down the road and the car started bogging real bad so I down shifted and gas it more gas but didnt help so I pull over and the car died. I try to start it back up but it wont start. When I turn the key to the on position I dont hear the fuel pump turning on. When I try to start it just cranks over but doesnt start. A friend of mine told me it might be the main relay. Where is the main relay located so i can test it? By the way it a '95 GSR
Thanks
Old Feb 19, 2006 | 12:40 PM
JDMC-Kamel's Avatar
Default Re: Wont Start (onepoint-gsr)
no way, that bad boy is done.
I can almost assure you that it is the timing belt!!
What is the mileage and hope you have deep pockets, good chance you bent all valves during down shift....
Know from customers experience.
Let me know if you need help....
Old Feb 19, 2006 | 12:42 PM
I just changed out the timing belt. mileage is about 140000.
Old Feb 19, 2006 | 12:45 PM
Nalude92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint-gsr &raquo;</TD></TR><TR><TD CLASS="quote">I just changed out the timing belt. mileage is about 140000.</TD></TR></TABLE>
Check out the distributor (cap,rotor, and ignitor chip). More than likely the ignitor or timing could be off. (fuel could be an option), check for spark first.
Old Feb 19, 2006 | 03:49 PM
veilsides2000's Avatar
pop your hood and have a friend or anybody turn the key into the on position and see if there is fuel going in. also check for spark. My car did the same thing and my fuel pump went bad.
Old Feb 19, 2006 | 06:43 PM
gsrwpower's Avatar
Default Re: Wont Start (veilsides2000)
you got no big problem here man. You got a bad battery going to the igintion system your spark plug wires may need to be changed. Your distrubuter cap may be faded out or your rotor inside that may be stuck.
Old Feb 19, 2006 | 08:54 PM
Brice.Hayden's Avatar
Default Re: Wont Start (integradude98)
pull a spark plug and look for oil...could be tube seals
bomar
Sep 2, 2010 02:23 PM
3M TA3
Jan 20, 2008 10:35 AM
DaKINE-Ek
13
Aug 15, 2006 10:57 AM
pbizzlegsr
Jul 7, 2004 10:23 PM
kicker1_solo
Apr 18, 2004 03:28 PM
