not goin in reverse
Old Feb 19, 2006 | 05:25 PM
JDMbitches's Avatar
Default not goin in reverse
my friend has 90 integra and it wont go in reverse. does this mean the tranny is goin out, or maybe just need to bleed the clutch?
Old Feb 19, 2006 | 06:48 PM
gsrwpower's Avatar
Default Re: not goin in reverse (JDMbitches)
the car will not go in to rearverse, well does the car sit outside in the driveway when it is cold out. Or it could just mean that you need to lub up the internal gear a little bit.
Old Feb 19, 2006 | 07:06 PM
JDMbitches's Avatar
Default Re: not goin in reverse (integradude98)
yea it does it just wont go in reverse. lub? did you mean lube?
Old Feb 19, 2006 | 08:25 PM
numbnuts22715's Avatar
yeah, im guessing thats what he means...
sometimes on a cold start its a little hard to get it in reverse on my car, and thats pretty typical with a lot of hondas...
tell him to rev up a tiny bit and then try to shift it into reverse.. that works for me.
Old Feb 19, 2006 | 08:27 PM
JDMbitches's Avatar
Default Re: (numbnuts22715)
i wish that was the case it just wont go in R would he have to get his tranny rebuilt or maybe something easy?
Old Feb 19, 2006 | 09:29 PM
BOOSTED RIVAL's Avatar
Default Re: (JDMbitches)
Will my B16 tranie did the same to. it will not go in to reverse so I got **** off and I rev my motor high and kick in the clutch and I push the shift really hard to reverse and let go off the clutch slowly and it grind and when in to reverse and after that no more problem. That how I fix my but it up to you I don't remmend if you don't know how to fix tranie.
Old Feb 19, 2006 | 09:52 PM
thaiphob's Avatar
Nikon!!!
Default Re: (BOOSTED RIVIL)
try shifting into another gear first like second...then try reverse.
Old Feb 20, 2006 | 04:23 AM
IN VTEC's Avatar
It could need the 5th-reverse synchro set replaced. The set isn't that expensive, and at worst, you might also need to replace the diff bearings (and diff clearance reshimmed), input shaft bearing, and the 5th-reverse shift fork if any of that stuff is called for when you look at it.
Old Feb 20, 2006 | 04:31 AM
LSvtec03's Avatar
Default Re: (IN VTEC)
btw, you have a cable tranny, not hydro, so you have nothing to bleed.
Old Feb 20, 2006 | 06:49 AM
Sam92Teg's Avatar
Default Re: (LSvtec03)
As stated earlier, it helps to engage a forward gear first. First push in the clutch, put the car in first and let out the clutch until it starts to engage, then press the clutch back in and try reverse, works everytime for me. Then check the level of his manual transmission fluid (MTF), or better yet, drain it and replace with fresh Honda MTF.
And lastly, if you have the original tranny, as stated earlier it is a cable tranny, so try adjusting the clutch engagement point if it isn't at the height spec required. Sometimes its a combination of low MTF with a poorly adjusted clutch and worn syncros from a 15 yr old tranny will make it really hard to get into reverse, but by using a forward gear first, which will become a habit, it usually will slip right in.
supereg2
Mar 21, 2008 09:51 AM
jaydem7
12
Sep 2, 2007 05:12 PM
mistahmac
Jul 15, 2007 03:13 PM
PrettyFastRide
13
Jul 13, 2006 06:30 AM
MrBite
Jun 13, 2002 12:48 PM
