abc light is on
Old Feb 19, 2006 | 08:49 PM
anonchild's Avatar
Default abc light is on
*abs light is on
what do I do?
I had my 30k maintance at 32 K.. now it is 34, besides changing oil, what else needs to be fixed/maintance/etc?
Old Feb 19, 2006 | 09:13 PM
justin.parker's Avatar
Default Re: abc light is on (anonchild)
what code is it throwing? That would probably help us assess what the problem is.
Old Feb 20, 2006 | 12:40 AM
anonchild's Avatar
Default Re: abc light is on (justin.parker)
the ABS lights up when I drive..
what do u mean code?.. I don't understand for I am kinda a newbie driver
Old Feb 20, 2006 | 05:13 AM
Dogginator's Avatar
Daisy... Daisy...
You can pull the ABS codes the same way that you pull the CEL (Check Engine Light) codes. Check this thread:
https://honda-tech.com/zerothread?id=978933
It is in the Integra FAQ section.
JDM_Keck's Avatar
what year is your car? by "code" he is referring to the process of using the jumper cable to make your car flash a certain code. when done, your check engine light with flash a series of dots and dashes similar to morse code. the dashes being in the numeric "ten" position (ex. 21, the 2 being the number represented by the dash. The short flashes or "dots" represent the number in the "ones" numeric position (ex.21)
I would check your fluids and make sure that all of you ABS wheel sensors are clean. If all else fails, take your car to the local honda/acura stealership and pay them to look into it for you
EDIT: the abs process is slightly different than the CEL process but if you are confident enough to do one, you are more than able to do the ABS check.
Modified by JDM_Keck at 9:23 AM 2/20/2006
EG8B16
Feb 9, 2016 07:51 PM
eg_boi
Aug 4, 2008 01:12 PM
egsauce
Aug 17, 2005 09:39 PM
quazar
Jul 13, 2004 06:53 PM
Blue teg
Dec 2, 2001 08:59 PM
