weird vibration under accel
so yea like it says when i shift into second sometimes third my car vibrates like a **** as if the axels were bad. the drivers inner joint was leaking neway so i changed both. the car was originaly auto to.so i changed out both with brand new1's. took it for a drive helped a little bit but still the same thing. it also has a coming and going vibration around 65-80. if i let of the gas vibration goes away back on it comes right back. im kinda stumped. the clutch is a 95 gsr with about 60K on it and im running 2000 gsr gears and a ls case. i also have the motor mount inserts and the auto to five speed polyurathane trans mount. wtf is up with my car?
id say the axles are bad...just because the axles look like they are in good condition doesn't mean they are...or your wheels arent balanced..
sounds like axles my buddies car is doing the same thing ill be changing his out a for a different set of used ones to see for sure before he buys new ones.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20integrapower »</TD></TR><TR><TD CLASS="quote">id say the axles are bad...just because the axles look like they are in good condition doesn't mean they are...or your wheels arent balanced..</TD></TR></TABLE>That's the reason why he replaced both axles....the problem was there before he replaced the axles. As far as wheel balance, I watched him do them quite a few times, just double checking himself. Any other ideas......this one has me stumped too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rajin »</TD></TR><TR><TD CLASS="quote">Bad spot on the tire, knots, flat spots from handbrake slides. Check all the tires conditions.</TD></TR></TABLE>
but he said that when he lets off the gas, the vibration goes away. if it was bad tires or unbalanced wheels, the vibration wouldn't stop would it?
to the thread starter, the only thing i can think of is to check your mounts really good. i know u said u have the inserts, but if the mount is torn, the inserts won't really help anything. since u replaced the axles i doubt thats the problem, but u could always try one more set. good luck.
It is not tires, wheels, or anything alignment related. If it were, the vibration would be there no matter if the throttle was open or not.
Did you replace both axles with 100% brand new units, or did you use rebuilts? Vibration while on the gas is almost hands-down a bad inner joint. I went through THREE sets of re-build CV axles (CCT-brand POS's) within a period of 2 months before finally getting a set that did not vibrate.
If you used rebuilt axles, I can pretty much guarantee you that you still got some bad inner joints.
i reaplced the aXEaxels this afternoon went for a drive no change. im gunna try a intermdeiate shaft being i got it used when i did my auto to five speed swap. if thats not it it may be the clutch since it used well see wat happens.
Shake down the front end. Get the front end off the ground, or on a lift, and try to move the tire up and down, then side to side, there should be NO play. If there is play up and down, its more than likely the wheel bearing(s), if it has side to side play, its more than likely the inner or outer tie rod ends. Mine has worn wheel bearings, and outer tie rod ends, and I have the same problem. I'm fixing mine this week as soon as I get my tax return, so I'll see if it solves my problem. Let me know if you have anymore questions.
well after ive replaced the axels now i have a new problem. whe im doing about 75=80 yea i still have the come and go vribration but now i got like a rubbing sound i can feel with my foot resting on the clutch pedal and my other foot on the gas this also comes and goes. i checked my tires and the inside edges are barley worn due to me being lazy and not buying a front camber kit ill swap them with my almost bald rear tires and see wats up. damnit can my week get any worse
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18B-SC »</TD></TR><TR><TD CLASS="quote">it may be you motor mounts, i had the same vibration, when i put the es motor mount inserts in my car it went away
if you would of read the thread from the begining i have the inserts already
</TD></TR></TABLE>if you would of read the thread from the begining i have the inserts already
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92DAIntegraXSI »</TD></TR><TR><TD CLASS="quote">
if you would of read the thread from the begining i have the inserts already</TD></TR></TABLE>
my bad
my bad
well one reason for this new noise is the dumbass's in my parts department gave my 94 ABS axesl which are to short so im waiting for my 3 pair to come in and yes another thing is the diff isnt looking to weel so looks like its time to pull my type r diff out of the box
kenttouchthis
Aug 24, 2008 04:09 PM
