does ign coil temperature make big difference???
Old Feb 21, 2006 | 02:05 PM
gutted's Avatar
Default does ign coil temperature make big difference???
today i checked the resistance on my coil and inside my house (60-70 degrees) .8 ohms and in my garage (20-30 degrees) 1.0 ohm. last week i checked the same coil and got 3.2 ohms (10-20 degrees), brought the coil inside my house and let it sit overnight then rechecked it and got 1.1 ohms. im leaning heavily on bad coil but im also curious if the temperature differences im getting is common.
BTW i know this is just on the primary side and i know specs are supposed to be 0.6-0.8 ohms
Old Feb 22, 2006 | 08:47 AM
BSQ's Avatar
BSQ
Default Re: does ign coil temperature make big difference??? (gutted)
This is from the Helms manual from the ignition section (pg 23-95).
NOTE: Resistance will vary with the coil temperature; specifications are at 68-degrees F (20-degrees C)
So, to answer your question. Yes.
CrAcKiN-VTEC
Aug 17, 2009 04:29 PM
crazyc@SRTmotorsports
Mar 11, 2007 12:59 AM
toooslow
Aug 20, 2003 09:12 PM
SIK IN DA HED
Jul 31, 2001 01:25 PM
