removing a cluster?
Old May 15, 2006 | 04:40 PM
slpr_civic93's Avatar
Default removing a cluster?
i need your help. ima switch my cluster to a type r. how do i take the cluster out of the dash? and install the type r cluster?
Old May 15, 2006 | 04:44 PM
94_DC4's Avatar
Default Re: removing a cluster? (slpr_civic93)
remove 2 philips head screws on the top side of the bezel and then pull it out . then there will be 3 screws holding the cluster in place, one on each side and one on the top. Then you can pull it out and unplug the cluster.
dohcMONSTER's Avatar
pull off the black cluster housing, then there are 3 screws you need to take out. (up,left and right) pull the cluster out and unplug the 2 plugs on the back. reverse for install
Old May 15, 2006 | 04:45 PM
DC2 Mang's Avatar
there are two scews on the garnish that goes around the cluster, thos must be removed first, they are located on the top portion
next there are three screws that hold the cluster in, one on top and one on each side
carefully remove the cluster, there should be two blue plugs and one small yellow one for ABS
than you are done, put the new cluster in the same way you took the old one out
ek4oreo
Jul 6, 2008 02:47 PM
bgod
Dec 17, 2002 12:12 PM
bgod
Dec 17, 2002 10:53 AM
