missing header bolt
Old May 17, 2006 | 11:22 AM
Maireeka's Avatar
Default missing header bolt
My current header is badly dented and leaking from the car being so low, and I've got a new 2 piece ebay header coming to take its place. My problem is that one of the bolts that holds the header onto the block is missing. Would this cause the leak, or if the other bolts are torqued properly will it not be a problem?
also, what is the torque spec for the header bolts?
thanks,
Patrick
Old May 17, 2006 | 12:06 PM
PrinceAli132's Avatar
Default Re: missing header bolt (Maireeka)
Not 100% sure its the same, but for a ITR its;
bracket bolts are 28lb/ft, spring bolts are 16lb/ft. Bolts on the outlet of cat are 25lb/ft.
And you'll be fine missing one bolt but get it fixed when you can.
Ali
Old May 17, 2006 | 07:33 PM
Maireeka's Avatar
Default Re: missing header bolt (PrinceAli132)
Would the honda dealership have that bolt in stock? I've never bought parts from a dealership but this seems to be something I can't just find at autozone haha.
MumBleZ_94gsR
Apr 23, 2009 10:29 PM
free99
Dec 31, 2007 01:26 PM
661rex89si
Jun 10, 2006 06:17 AM
JohnQPublic
May 26, 2006 07:15 PM
NATURAL ASPIRATI0N
Oct 22, 2003 03:09 PM
