b18a to b20
Old May 17, 2006 | 09:59 AM
DA is best's Avatar
Default b18a to b20
i want a b20 because my b18a is tired, what all do i have to do to do the swap can i still use my stock harness......it's going into a 92 integra with b18a
Old May 17, 2006 | 07:23 PM
DA is best's Avatar
anyone
Old May 17, 2006 | 07:49 PM
silva95teg's Avatar
yeah i am not 100 percent but i am pretty sure it should bolt right in.
Old May 17, 2006 | 09:03 PM
B-Hatchie's Avatar
Default Re: (silva95teg)
take everthing off the b18 and put it on the b20. I did that when b18b spun a rod bearing in my 94 coupe. Love the torque
Old May 18, 2006 | 09:33 AM
DA is best's Avatar
i dont want a xsi motor because i dont have $1700 otherwise i would in a heartbeat
Old May 18, 2006 | 09:42 AM
joehansen1232000's Avatar
Default question in changin b18a head to 99 b18b head?????
will the 99 b18b head bolt right on to my 91 integra or do i have to make any mods??
Old May 18, 2006 | 08:19 PM
DA is best's Avatar
just use your dizzy, IM, and injectors
Old May 18, 2006 | 10:39 PM
b20powereDA's Avatar
Default Re: (derek21)
its a direct swap. use ur dizzy, ecu, wiring harness, and im. if i were u i wouldnt do it. especially if there is nothing critically wrong with ur motor. not to much faster than ls. jus save up for a vtec head and go ls/vtec. jus my opinion
Old May 18, 2006 | 10:49 PM
VHOA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by derek21 &raquo;</TD></TR><TR><TD CLASS="quote">just use your dizzy, IM, and injectors</TD></TR></TABLE>
then you can utilize your stock harness
Old May 21, 2006 | 07:59 PM
DA is best's Avatar
i would get a vtec head but my motor has 235,000 miles on it so im tossin it, and gettin a new one
Old May 21, 2006 | 08:49 PM
IntegraLova's Avatar
Like others have said, save up for a better swap.It would suck to end up getting a b20b and actually lose alota hp.Im pretty sure they only have 120hp due to lower compression.Just something for u to think about.
Old May 21, 2006 | 09:02 PM
lVlemphizStylez's Avatar
Default Re: (IntegraLova)
get the b20...ppl that are saying no to b20 probably have no first hand experience with it...torque is important...
Golden Example: 99 si vs ls...same quarter mile times...despite the gearing advantage the si has..why? because torque matters
Old May 21, 2006 | 10:55 PM
b20integrapower's Avatar
Default Re: (lVlemphizStylez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">get the b20...ppl that are saying no to b20 probably have no first hand experience with it...torque is important...
Golden Example: 99 si vs ls...same quarter mile times...despite the gearing advantage the si has..why? because torque matters</TD></TR></TABLE>
thanks for stickin up for the b20 guys..i love my motor..and i have no regrets getting it...its a damn good motor for 650-700 bucks
Old May 21, 2006 | 11:45 PM
Noemotion_91DA's Avatar
Default Re: (b20integrapower)
If you decide to go b20 try to find a b20z block, that way you will have a higher compression ratio. Either way you love the torque that the b20b,b20z has.
Old May 22, 2006 | 09:13 PM
DA is best's Avatar
k cool i'll try to get the b20z because i also want a b16 head in the near future as well
Old May 22, 2006 | 11:07 PM
i know first hand what its like. my daily driver currently has a b20 in it. oh and by the way, a stock b20 makes more power than 120 hp. i know they are rated at 120 hp and 133 tq, but ive seen dynos of stock b20s doin like 130-140 whp. i jus think they are rated low. well i see ur motor has a fuckload of miles on it so yea go ahead and swap, but first what u should do is order ur b16 head and a a b16 tranny and jus go ahead and do b20 vtec of the bat. ill be goin b20 vtec this weekend wit mild cams and bolt ons. should be fun. while u got ur motor out u should go ahead and get flywheel/clutch combo. i know its a lot of money and all but u will have no down time if u build ur mototr while u got one thats running in the car. is there anything specifically wrong with ur motor or does it jus have alot of miles? burn oil?
Old May 23, 2006 | 05:29 AM
DA is best's Avatar
well the head gasket leaks, needs a new cam seal....and right now its acting wierd like when the motor is cold its runs ok but when it warms up it runs like crap and i mean CRAP it ides low like its about to die and i have no power what so ever it like i have 50hp when i floor it, and when i normaly drive it liek bogs utill like 3,000rpm i live and work in town so i never go above that unless im racing, so i havent yet figured out the problem, i dont know what to do.....and when i get my new motor i will get new clutch/flywheel
Old May 23, 2006 | 11:59 AM
B_CRUZ!'s Avatar
Default Re: (b20powereDA)
B20's are rated low because of the intake manifold and exhaust manifold. Put a 94+ up or skunk2 Intake manifold and get a decent header like a 96 ITR 4-2-1 with a 2.5" collector and it will make a lot more hp and torque. Also try to get a 92-93 GS-R tranny with the shorter gears.
The motor will work in the DA if you transfer over everything.(i.e mounts, distributer, alternator, fuel injectors, wiring harness, thermostat housing.)
Old May 23, 2006 | 07:32 PM
DA is best's Avatar
cool, because i actualy have a b18b intake manifold in my room right now that i can use
Old May 23, 2006 | 08:05 PM
Dieselinvasian's Avatar
b20 is awsome....i swapped out my ls motor for a b20 and it felt way faster..just ignore those stock hp numbers....i think its faster than LS and i've beaten b16 's not GSRS though...but F them b20 .... once you get it you'll never go lower than 2.0 ---- currently b20b turbo
Old May 23, 2006 | 08:09 PM
Extreez's Avatar
Default Re: (Dieselinvasian)
if u havent done this yet, take my word dont do a b20 swap, i had a integra with b20, its picks up and everything better but TOO MANY PROBLEMS within a month the car choked no one knew what was wrong with it so i sold it
Old May 23, 2006 | 08:24 PM
PLAGUED_DB7's Avatar
Default Re: (Extreez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Extreez &raquo;</TD></TR><TR><TD CLASS="quote">if u havent done this yet, take my word dont do a b20 swap, i had a integra with b20, its picks up and everything better but TOO MANY PROBLEMS within a month the car choked no one knew what was wrong with it so i sold it </TD></TR></TABLE>
Did you buy junk?
Old May 23, 2006 | 09:30 PM
DA is best's Avatar
well, everything i've herd so far is good news but it's still 50% of ppl are say yes get it and the other 50% are sayin no....so damnit i just dont know
Old May 23, 2006 | 09:37 PM
what problems would you have with a b20, that you would be avoiding with any other 4 cylinder honda motor? name some problems...i bet they are problems seen before with any other motor.
HksHaitian
Nov 14, 2008 10:28 AM
stratedrm
Aug 8, 2007 09:31 AM
jbell
Dec 7, 2004 06:08 AM
civic5483
31
Mar 7, 2004 11:13 AM
whoDAT
23
Oct 7, 2003 02:17 PM
