Overheat!!
Old May 18, 2006 | 09:10 AM
gs_rbaby's Avatar
Default Overheat!!
Have a 95 integra GS-R. Replaced the radiator, radiator cap, thermastat, waterpump, has 156k. Over heats when the Radiator runs out of fluids. Anyone knows what could be the cause of this madness?
Old May 18, 2006 | 09:13 AM
Mt3c's Avatar
25 Year Member
Default Re: Overheat!! (gs_rbaby)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gs_rbaby &raquo;</TD></TR><TR><TD CLASS="quote">Over heats when the Radiator runs out of fluids. </TD></TR></TABLE>
Thats general the case for all cars.
The question is, why does your car run out of fluids? I'm guessing a blown head gasket and you're burning all the coolant up since you already mentioned you replaced the water pump and radiator. Are you leaking fluid anywhere?
Old May 18, 2006 | 01:34 PM
gs_rbaby's Avatar
Default Re: Overheat!! (Mt3c)
no, does not leak anywhere. no signs or trace of leaks. Maybe the head gasket. thanks!
Old May 18, 2006 | 01:36 PM
Code's Avatar
Not now Chief, I'm in the F'n zone!
is your car blowing white smoke? also, why make 2 threads about this?
https://honda-tech.com/zerothread/1631546
Old May 19, 2006 | 01:27 PM
gs_rbaby's Avatar
Default Re: Overheat!! (Code)
no, no white smoke at all. just trying to get more answers if the topic was overlooked. but, thanks for the input.
Old May 19, 2006 | 01:34 PM
LoseRPunKx182's Avatar
are u bleeding and refilling it correctly with the bleeding bolt off
Old May 19, 2006 | 02:03 PM
mickey513's Avatar
more than likely it's the headgasket...
Old May 19, 2006 | 02:08 PM
-Darren-'s Avatar
Default Re: Overheat!! (mickey513)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mickey513 &raquo;</TD></TR><TR><TD CLASS="quote">more than likely it's the headgasket...</TD></TR></TABLE>
94ls
May 17, 2009 03:23 PM
R-81 Coupe
Sep 26, 2006 10:36 AM
dynastix9
Dec 18, 2005 06:33 AM
kublai
May 22, 2005 08:30 PM
blackEF
Oct 29, 2002 12:24 PM
